Sub Woofer Installation, Tried to get better Audio without carving up the car |
ctc911ctc |
Jan 28 2019, 06:42 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
Been silent, very cold - garage is a 100 year old Yankee version, no heat.....will not hold any. So, my 17yr old son and I decided to upgrade the speakers (the old ones were absent any cone material). Found a set of KFC-4675C (kenwood) that fit the spec, integrated mid range and tweeter. Now for the low range. We decided that carving up the car and running a large alternator and battery was not for this car, we are trying to restore it to 80-90 points. So we are using a passive crossover, the original tuner with a power amp that was installed in the 80s, still works (both units are Blauplunkt). We have about 40 watts - more than enough for the size of the car. When we rebuilt the car we installed sound deadening material in the engine bay, passenger compartment and will put it in the trunk. Amazing how quiet the car seems in the passenger compartment now. My son had the idea to install the Subwoofer in the engine compartment, cut through the back seat - had to explain the concept of FireWall to him, we looked at a dozen other places and settled on what I think is a very elegant solution. Our car is a '74 2.0, Silver. So it has a center console. We are installing it there! First, where should the speaker go???? Wow - no particle board - furniture grade ply! Peel back the Vinyl, careful! Counter sync for flush hidden finish Score the vinyl, perhaps we can STRETCH it! Heat gun and PULL, gently Look at that circle, no wood showing, barely a wrinkle! Add a screen Bolt that Micro SubWoofer in place What the Passenger will see Perfect Fit Passive Crossover Will post a note as to how this sounds in a few weeks (months?) Attached image(s) |
horizontally-opposed |
Jan 18 2020, 07:25 PM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Maybe a stupid question, but: Could the doors be used more effectively when it comes to bass? I'm wondering if a 6.5 in the door with a small port tube venting back into the interior (by the back of the door, near the seat?) would work better than simply placing the speaker in the usual spot?
I am also wondering if one might figure out a way to mount said 6.5 behind the door panel and then make holes between the bricks in the door card's basketweave in a (perhaps compromised) version of the speaker holes seen in early 928s. Just thinking out loud here; not sure what the ramifications would be in audio terms. If we have any audio experts, I'd love to hear from them. |
steuspeed |
Jan 19 2020, 06:14 PM
Senior Member Group: Members Posts: 1,005 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Maybe a stupid question, but: Could the doors be used more effectively when it comes to bass? I'm wondering if a 6.5 in the door with a small port tube venting back into the interior (by the back of the door, near the seat?) would work better than simply placing the speaker in the usual spot? I am also wondering if one might figure out a way to mount said 6.5 behind the door panel and then make holes between the bricks in the door card's basketweave in a (perhaps compromised) version of the speaker holes seen in early 928s. Just thinking out loud here; not sure what the ramifications would be in audio terms. If we have any audio experts, I'd love to hear from them. You could do a 3 way separate system. One Idea I had for my car with already cut door panels. Buy a 3 way kit. Use the tweet and mid under the stock grill and the woofer in the door. |
Lo-Fi Version | Time is now: 26th April 2024 - 08:30 AM |
