Sub Woofer Installation, Tried to get better Audio without carving up the car |
ctc911ctc |
Jan 28 2019, 06:42 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
Been silent, very cold - garage is a 100 year old Yankee version, no heat.....will not hold any. So, my 17yr old son and I decided to upgrade the speakers (the old ones were absent any cone material). Found a set of KFC-4675C (kenwood) that fit the spec, integrated mid range and tweeter. Now for the low range. We decided that carving up the car and running a large alternator and battery was not for this car, we are trying to restore it to 80-90 points. So we are using a passive crossover, the original tuner with a power amp that was installed in the 80s, still works (both units are Blauplunkt). We have about 40 watts - more than enough for the size of the car. When we rebuilt the car we installed sound deadening material in the engine bay, passenger compartment and will put it in the trunk. Amazing how quiet the car seems in the passenger compartment now. My son had the idea to install the Subwoofer in the engine compartment, cut through the back seat - had to explain the concept of FireWall to him, we looked at a dozen other places and settled on what I think is a very elegant solution. Our car is a '74 2.0, Silver. So it has a center console. We are installing it there! First, where should the speaker go???? Wow - no particle board - furniture grade ply! Peel back the Vinyl, careful! Counter sync for flush hidden finish Score the vinyl, perhaps we can STRETCH it! Heat gun and PULL, gently Look at that circle, no wood showing, barely a wrinkle! Add a screen Bolt that Micro SubWoofer in place What the Passenger will see Perfect Fit Passive Crossover Will post a note as to how this sounds in a few weeks (months?) Attached image(s) |
dr914@autoatlanta.com |
Jan 24 2020, 10:12 AM
914 Guru Group: Members Posts: 7,838 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the best place is to put a sub woofer is where the foam floor board block exists on the passenger side. Totally hidden, takes up no space, sounds GREAT and does not chop up the car. Here is a picture if anyone wants to make one: http://www.autoatlanta.com/Porsche-914-Spe...N-BAA31934.html
It is very easy to make, basically the pattern of the block with a leg to support it. We have made hundreds over the years and the sound is great, and TOTALLY hidden |
horizontally-opposed |
Jan 24 2020, 11:45 AM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
the best place is to put a sub woofer is where the foam floor board block exists on the passenger side. Totally hidden, takes up no space, sounds GREAT and does not chop up the car. Here is a picture if anyone wants to make one: http://www.autoatlanta.com/Porsche-914-Spe...N-BAA31934.html It is very easy to make, basically the pattern of the block with a leg to support it. We have made hundreds over the years and the sound is great, and TOTALLY hidden This isn't an ideal solution. A subwoofer will perform far better in a sealed and ported enclosure. But it might be better than nothing.… check this thread out. my sub box that is now sold by 914rubbers is in post 15 and 16/ it's a good tight bass with good volume. http://www.914world.com/bbs2/index.php?sho...mp;hl=subwoofer ^ THIS is the way to go, or at least the way I'd like to go. The first one shows how the box should be done, while the second and third are more appealing to those of us who want a truly stealth setup. How to the ones where you can't see the subwoofer sound? And you say they're available from 914Rubber? (IMG:style_emoticons/default/idea.gif) Attached image(s) |
drem914 |
Jan 24 2020, 11:58 AM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
the best place is to put a sub woofer is where the foam floor board block exists on the passenger side. Totally hidden, takes up no space, sounds GREAT and does not chop up the car. Here is a picture if anyone wants to make one: http://www.autoatlanta.com/Porsche-914-Spe...N-BAA31934.html It is very easy to make, basically the pattern of the block with a leg to support it. We have made hundreds over the years and the sound is great, and TOTALLY hidden This isn't an ideal solution. A subwoofer will perform far better in a sealed and ported enclosure. But it might be better than nothing.… check this thread out. my sub box that is now sold by 914rubbers is in post 15 and 16/ it's a good tight bass with good volume. http://www.914world.com/bbs2/index.php?sho...mp;hl=subwoofer ^ THIS is the way to go, or at least the way I'd like to go. The first one shows how the box should be done, while the second and third are more appealing to those of us who want a truly stealth setup. How to the ones where you can't see the subwoofer sound? And you say they're available from 914Rubber? (IMG:style_emoticons/default/idea.gif) what do you do to protect the sealed box speaker (lower left) from feet? |
Lo-Fi Version | Time is now: 8th May 2024 - 06:00 AM |
