flare question |
flare question |
GWN7 |
Feb 4 2003, 04:38 PM
How much extra width do the 6 style flares add to a car? It appears to be about 4"-5" per side. I bought a roller with these style flares on it and want to know if it will fit in the back of my 1/2 ton or if I will have to haul the dolly down to get it.
Mueller |
Feb 4 2003, 05:21 PM
I can measure my trailer tonight....sorry for not getting back to you earlier (IMG:style_emoticons/default/sad.gif)
Feb 4 2003, 05:39 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
hey brad, get that tape-measure out and give this guy some numbers!
(IMG:style_emoticons/default/cool.gif) Andy |
jonwatts |
Feb 4 2003, 05:57 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
Brad should be picking your car up or delivering it back to Yeaman's Autobody by now.
There is at least one company out there making a larger version of GT flare that will let you get 11's under the back of your car. Doubtful you have these but it's good to make sure. Jon |
Feb 4 2003, 06:22 PM
QUOTE(jonwatts @ Feb 4 2003, 03:57 PM) Brad should be picking your car up or delivering it back to Yeaman's Autobody by now. There is at least one company out there making a larger version of GT flare that will let you get 11's under the back of your car. Doubtful you have these but it's good to make sure. Jon that explains the silence (IMG:style_emoticons/default/smile.gif) man, can't wait to get the paint done. as for the extra wide flares, i've seen them a few times now. but those are way bigger ... (IMG:http://www.pelicanparts.com/catalog/images/chassis/914_chassis/914_11.jpg) |
GWN7 |
Feb 4 2003, 07:13 PM
It doesn't have the extra wide ones.....this one I'm going to do a V8 conversion with (next year) (IMG:style_emoticons/default/smile.gif)
Jeroen |
Feb 4 2003, 07:46 PM
I just measured my car in the garage...
It's 175 cm wide in the rear HTH, Jeroen |
Feb 4 2003, 07:51 PM
QUOTE(Jeroen @ Feb 4 2003, 05:46 PM) I just measured my car in the garage... It's 175 cm wide in the rear HTH, Jeroen and for those of you who are not familiar with metric measurements, that is just a little bit under 69 inches ... |
Mike T |
Feb 4 2003, 07:55 PM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
I get 69" at the rear.
Mike T |
Jeroen |
Ayup, but since GWN7 is in canada I could save searching for my calculator (IMG:style_emoticons/default/biggrin.gif)
cheers, Jeroen |
Mark Henry |
Feb 4 2003, 08:47 PM
QUOTE(Jeroen @ Feb 4 2003, 05:55 PM) Ayup, but since GWN7 is in canada I could save searching for my calculator (IMG:style_emoticons/default/biggrin.gif) cheers, Jeroen Maybe, depends on his age, we have only had the metric system for a little over 30 years here and we still have some hold outs. But if you ask a kid what a foot is, they point at their shoe. Some Canadians are bi-lingual, I guess a lot are bi-measuremental and of course we have some that a just bi- (IMG:style_emoticons/default/smlove2.gif) (IMG:style_emoticons/default/barf.gif) |
GWN7 |
Feb 4 2003, 09:04 PM
Thanks guys.
2.5cm = 1" Way over 30....I have T-shirts older than that (IMG:style_emoticons/default/smile.gif) |
Mueller |
Feb 4 2003, 09:36 PM
Bruce,
the tire rack on my trailer is 70.5 inches wide.....when I brought home the /6, I had ~1 inch on each side of the front fenders I did slightly scratch one fender flare while putting the car on the trailer...luckly it can be rubbed out....... |
Lo-Fi Version | Time is now: 19th May 2024 - 10:38 PM |
