914-6 soft line group buy? |
mb911 |
Feb 5 2019, 08:15 PM
914 Guru Group: Members Posts: 6,830 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am about to order a bunch of 914-6 soft lines and wanted to see if anyone needed a set at a great price.
The 3 soft lines that work for a stock 914-6 $285 shipped Same as above but all 30mm fittings for larger scavange line $300 shipped.. I believe I am cheaper then anyone on these and they are cohline brand. |
914forme |
Feb 9 2019, 07:05 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Ben, make sure my set has the proper fittings, your oil tank, your larger scavenger line, and 30mm off the oil cooler. So I guess I need all 30mm (IMG:style_emoticons/default/confused24.gif)
mb911 |
Feb 9 2019, 10:10 AM
Ben, make sure my set has the proper fittings, your oil tank, your larger scavenger line, and 30mm off the oil cooler. So I guess I need all 30mm (IMG:style_emoticons/default/confused24.gif) Stephen good catch.. I was about to package up a standard set for you with the muffler.. |
Lo-Fi Version | Time is now: 7th May 2024 - 10:53 AM |
