Front trunk will not open, been sitting |
jrblackbox |
Feb 7 2019, 07:08 AM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
1973 914 has been sitting for many years, the handle does not budge. How can I get that front trunk open? TIA
Jazzy |
Feb 7 2019, 07:12 AM
Newbie Group: Members Posts: 32 Joined: 16-September 17 From: The Netherlands Member No.: 21,432 Region Association: Europe |
Remove the front bumper with the 4 bolts from the wheel wells, two on each side. Then you'll see a small hole in the front where the lock can be released with a screw driver.
But before you do that, make sure the handle isn't locked with the key. (IMG:style_emoticons/default/smile.gif) |
jrblackbox |
Feb 7 2019, 07:42 AM
Remove the front bumper with the 4 bolts from the wheel wells, two on each side. Then you'll see a small hole in the front where the lock can be released with a screw driver. But before you do that, make sure the handle isn't locked with the key. (IMG:style_emoticons/default/smile.gif) There aren't any keys. will it make a difference if it is locked? |
BeatNavy |
Feb 7 2019, 07:43 AM
Quickest thing to try is have someone push down on the lid while you try to pull the handle. Take the tension off of it.
If that doesn't work, then yes, you need to remove the bumper. On the body you'll find a hole in which a screwdriver or something can be inserted to move the catch. Once you do get it open, clean and lubricate all moving parts. |
Feb 7 2019, 08:32 AM
Quickest thing to try is have someone push down on the lid while you try to pull the handle. Take the tension off of it. If that doesn't work, then yes, you need to remove the bumper. On the body you'll find a hole in which a screwdriver or something can be inserted to move the catch. Once you do get it open, clean and lubricate all moving parts. (IMG:style_emoticons/default/agree.gif) lubing up the cable, latch and pull will keep it from getting stuck again. Same with all the locks, window winders and cables on our cars. |
GregAmy |
Feb 7 2019, 10:53 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
But before you do that, make sure the handle isn't locked with the key. (IMG:style_emoticons/default/smile.gif) There aren't any keys. will it make a difference if it is locked? Yes: if it's locked then the handle cannot be pulled. Whether it's a locked handle, a frozen cable, or a sticky latch, you should be able to trip the latch with a screwdriver after the bumper is removed. Then you can troubleshoot. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:29 PM |
