QUOTE(BeatNavy @ Feb 7 2019, 08:43 AM)
Quickest thing to try is have someone push down on the lid while you try to pull the handle. Take the tension off of it.
If that doesn't work, then yes, you need to remove the bumper. On the body you'll find a hole in which a screwdriver or something can be inserted to move the catch.
Once you do get it open, clean and lubricate all moving parts.
lubing up the cable, latch and pull will keep it from getting stuck again. Same with all the locks, window winders and cables on our cars.
