A few disconnected parts |
isdyl |
Feb 9 2019, 07:10 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi - so I'm just preparing for my maiden voyage - the car must have been off the road for at least 10 years judging by the rust in the floor when I got it in June. I've changed the fan belt this morning, but there are a few thingsI saw that I think need tidying. Its got a mid mounted progressive weber (yes I know), and there looks to be a port on each side near where the headers meet the tin - should some pipes be connected to these please? Also in one photo showing the port on the passenger side there is a wire coming out of the tin with a female spade connector - you can see it in the photo. There is also a green with red trace wire coming out of the loom near the distributor which isn't connected to anything.
The car runs, but not well. Not sure how far I will get down the road! Thanks, Dylan Attached image(s) |
Rob-O |
Feb 18 2019, 07:22 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
With the center mounted carb there is usually a spring from the carb to the tin at the back of the engine. That snaps the throttle plate closed.
I agree with Clay, though. I’d look into sourcing the FI parts and reinstall it. Car runs so much better with FI (and Clay was a huge help getting mine up and running). |
isdyl |
Feb 19 2019, 01:50 AM
Thanks - I would definitely consider FI but there are a lot of parts missing that I would need and over here in the uk they are few and far between. I’m not sure if it would be L or D-jetronic being a ‘73 but assuming D there’s airbox, throttle body, MPS, ECU, injectors, inlet runners etc etc. There’s no doubt FI would be nicer to have, but it’s a lot of work and expense. At least a pair or Weber 40’s are sold over here for type 4 engines.
With the center mounted carb there is usually a spring from the carb to the tin at the back of the engine. That snaps the throttle plate closed. I agree with Clay, though. I’d look into sourcing the FI parts and reinstall it. Car runs so much better with FI (and Clay was a huge help getting mine up and running). |
ClayPerrine |
Feb 19 2019, 06:47 AM
Life's been good to me so far..... Group: Admin Posts: 15,436 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Thanks - I would definitely consider FI but there are a lot of parts missing that I would need and over here in the uk they are few and far between. I’m not sure if it would be L or D-jetronic being a ‘73 but assuming D there’s airbox, throttle body, MPS, ECU, injectors, inlet runners etc etc. There’s no doubt FI would be nicer to have, but it’s a lot of work and expense. At least a pair or Weber 40’s are sold over here for type 4 engines. With the center mounted carb there is usually a spring from the carb to the tin at the back of the engine. That snaps the throttle plate closed. I agree with Clay, though. I’d look into sourcing the FI parts and reinstall it. Car runs so much better with FI (and Clay was a huge help getting mine up and running). How do you get dual Webers passed the MOT?? |
Lo-Fi Version | Time is now: 4th May 2024 - 08:15 PM |
