A few disconnected parts |
isdyl |
Feb 9 2019, 07:10 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi - so I'm just preparing for my maiden voyage - the car must have been off the road for at least 10 years judging by the rust in the floor when I got it in June. I've changed the fan belt this morning, but there are a few thingsI saw that I think need tidying. Its got a mid mounted progressive weber (yes I know), and there looks to be a port on each side near where the headers meet the tin - should some pipes be connected to these please? Also in one photo showing the port on the passenger side there is a wire coming out of the tin with a female spade connector - you can see it in the photo. There is also a green with red trace wire coming out of the loom near the distributor which isn't connected to anything.
The car runs, but not well. Not sure how far I will get down the road! Thanks, Dylan Attached image(s) |
mgphoto |
Feb 19 2019, 12:22 PM
"If there is a mistake it will find me" Group: Members Posts: 1,338 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
'73 model year, the angle of the spark plug says it's a 1.7, that model is D Jet and the '72 and '72 share the same system, which is the least wanted, meaning the parts are the cheapest!
Biggest problem with the dual Webers is that it wont run any better than the carb that is on it now. The reason is that it most certainly has the original cam which is Fuel Injected. The po didn't spend any real money on the induction system hence the crappy carb, and I doubt that the case was split for a cam install. There looks to be some missing hoses for the crankcase breather, easy fix. We have access to several great websites with a lot of D-Jet info and I bet you that the greater majority of cars that were brought back to there D-Jet systems are better running cars than their carbbed counterparts. MY $.02 on this side of the pond. |
isdyl |
Feb 19 2019, 02:29 PM
Thanks for the info. D-jetronic is good news as I know the system inside out from a couple of early Mercedes r107's I had in the past. Interesting what you say about the cam too - it's something I have heard before. Ok then, I'll start looking out for a FI system and not waste money on any more carbs. I guess I need to start by making a list of everything I need. D
'73 model year, the angle of the spark plug says it's a 1.7, that model is D Jet and the '72 and '72 share the same system, which is the least wanted, meaning the parts are the cheapest! Biggest problem with the dual Webers is that it wont run any better than the carb that is on it now. The reason is that it most certainly has the original cam which is Fuel Injected. The po didn't spend any real money on the induction system hence the crappy carb, and I doubt that the case was split for a cam install. There looks to be some missing hoses for the crankcase breather, easy fix. We have access to several great websites with a lot of D-Jet info and I bet you that the greater majority of cars that were brought back to there D-Jet systems are better running cars than their carbbed counterparts. MY $.02 on this side of the pond. |
Lo-Fi Version | Time is now: 4th May 2024 - 04:28 PM |
