A few disconnected parts |
isdyl |
Feb 9 2019, 07:10 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi - so I'm just preparing for my maiden voyage - the car must have been off the road for at least 10 years judging by the rust in the floor when I got it in June. I've changed the fan belt this morning, but there are a few thingsI saw that I think need tidying. Its got a mid mounted progressive weber (yes I know), and there looks to be a port on each side near where the headers meet the tin - should some pipes be connected to these please? Also in one photo showing the port on the passenger side there is a wire coming out of the tin with a female spade connector - you can see it in the photo. There is also a green with red trace wire coming out of the loom near the distributor which isn't connected to anything.
The car runs, but not well. Not sure how far I will get down the road! Thanks, Dylan Attached image(s) |
isdyl |
Jan 16 2020, 04:16 AM
Hi - I'm just eventually starting to fit the d-jetronic FI which Clay kindly sent me onto my 1.7 '73 car. I've stripped off the single webber and am just taking it slowly, and buying bits as I need them. I am currently swapping out the distributor to the FI one with the trigger points, and I just wondered if it mattered which way round the body goes please? It only seems to fit in a few positions due to the vacuum canister on the side, and obviously I will need to rotate it to set the timing, but do the trigger points fire all the cylinders each quarter turn please? I seem to remember from a V8 mercedes I had once that the injectors fired in pairs.
Thanks, Dylan |
Lo-Fi Version | Time is now: 4th May 2024 - 04:54 PM |
