A few disconnected parts |
isdyl |
Feb 9 2019, 07:10 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi - so I'm just preparing for my maiden voyage - the car must have been off the road for at least 10 years judging by the rust in the floor when I got it in June. I've changed the fan belt this morning, but there are a few thingsI saw that I think need tidying. Its got a mid mounted progressive weber (yes I know), and there looks to be a port on each side near where the headers meet the tin - should some pipes be connected to these please? Also in one photo showing the port on the passenger side there is a wire coming out of the tin with a female spade connector - you can see it in the photo. There is also a green with red trace wire coming out of the loom near the distributor which isn't connected to anything.
The car runs, but not well. Not sure how far I will get down the road! Thanks, Dylan Attached image(s) |
rjames |
Feb 11 2020, 06:13 PM
I'm made of metal Group: Members Posts: 3,922 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Last pic is of the decel valve. Mounted on the same bracket as the MPS (in a 2 liter at least).
Thread about how it’s hooked up (and more) here: http://www.914world.com/bbs2/index.php?sho...c=67150&st= |
isdyl |
Feb 12 2020, 01:16 AM
Last pic is of the decel valve. Mounted on the same bracket as the MPS (in a 2 liter at least). Thread about how it’s hooked up (and more) here: http://www.914world.com/bbs2/index.php?sho...c=67150&st= Ah ok thanks - so that upper left port on my photo probably should be 'Decel Valve' with the other pipe from the decelerations valve going to the air filter box. So that just leaves the right hand port which maybe goes to the oil filler tower? Or does the oil filler tower connect to the air filter box to please? |
Lo-Fi Version | Time is now: 4th May 2024 - 07:39 PM |
