outside door handles, rechrome ? |
rgalla9146 |
Feb 9 2019, 05:01 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Anyone here have any luck re-chroming outside door handles ?
I've got a couple good ones, just need better chrome. Also, a source for the handle pivot/rivet ? |
Feb 9 2019, 05:17 PM
I believe Tweet offers that service.
ConeDodger |
Feb 9 2019, 05:33 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Be careful. Whoever does it needs to understand that chroming the back articulating part renders them pretty much uselesss as the bushings will no longer fit. It can be worked around, but if you make sure they don’t do it up front, you don’t have to deal with it on reassembly.
porschetub |
Feb 9 2019, 09:55 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Information indicates they are made of "pot metal",someone correct me if I'am wrong please ?,it would take a clever metal finisher to prep them for rechroming even after the old chrome is neutralized ,there is a reasonable supply of used ones even those with the broken mounting tab which is a fairly easy fix and cheap to buy.
I don't know the quality of the repro ones but suspect they could be better than originals in construction but quality of chrome may cause issues after a period of time (IMG:style_emoticons/default/confused24.gif) . |
Feb 9 2019, 10:23 PM
Information indicates they are made of "pot metal",someone correct me if I'am wrong please ?,it would take a clever metal finisher to prep them for rechroming even after the old chrome is neutralized ,there is a reasonable supply of used ones even those with the broken mounting tab which is a fairly easy fix and cheap to buy. I don't know the quality of the repro ones but suspect they could be better than originals in construction but quality of chrome may cause issues after a period of time (IMG:style_emoticons/default/confused24.gif) . The reproductions aren't very good. The "chrome" almost rubs off by hand. I've seen some that Tweet/Dan has redone and they look great but I know rechroming has gotten VERY expensive. |
rgalla9146 |
Feb 10 2019, 06:59 AM
Information indicates they are made of "pot metal",someone correct me if I'am wrong please ?,it would take a clever metal finisher to prep them for rechroming even after the old chrome is neutralized ,there is a reasonable supply of used ones even those with the broken mounting tab which is a fairly easy fix and cheap to buy. I don't know the quality of the repro ones but suspect they could be better than originals in construction but quality of chrome may cause issues after a period of time (IMG:style_emoticons/default/confused24.gif) . The reproductions aren't very good. The "chrome" almost rubs off by hand. I've seen some that Tweet/Dan has redone and they look great but I know rechroming has gotten VERY expensive. I've messaged Tweet.....fingers crossed |
914dave |
Feb 10 2019, 07:33 AM
914 Addict Group: Members Posts: 701 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
I bought repos from Sierra Madre. They look nice but would bind. Had to take them apart and remove chrome in the pivots. Works well now and looks good. Of course they may not be up to your quality standards. But they were good enough for my car. (IMG:style_emoticons/default/wink.gif)
rgalla9146 |
Feb 10 2019, 07:50 AM
I bought repos from Sierra Madre. They look nice but would bind. Had to take them apart and remove chrome in the pivots. Works well now and looks good. Of course they may not be up to your quality standards. But they were good enough for my car. (IMG:style_emoticons/default/wink.gif) Dave You should talk ! Can't wait to break each others chops in person. (IMG:style_emoticons/default/beerchug.gif) Repro parts are often a crap shoot. You were able to make them work, that's better than some stuff. |
914Sixer |
Feb 10 2019, 08:03 AM
New ones are available in the $250 to $300 range from Porsche
mb911 |
Feb 10 2019, 08:05 AM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Cairo94507 |
Feb 10 2019, 09:06 AM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Tweet did all of my lock assemblies so they are all keyed to a new key he made. He also did my door handles and he had to clearance them once they returned from the chrome shop so they worked as new. We have not installed them yet, but I definitely needed to have all of the locks rekeyed and restored. Tweet and his wife are the real deal when it comes to this task.
Lo-Fi Version | Time is now: 17th May 2024 - 06:51 PM |
