123 Distributor group buy (Feb 2019), *** 10% discount, extended to March 24th *** |
mobymutt |
Feb 11 2019, 01:57 PM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Ed at Ignition123USA has kindly agreed to give us a discounted price again this year.
Here is his PM to me: "Hi Matt Sure we can do a group buy. I will set up the code 914GB19 It will give you 5% off If it reaches 10 customers you will be refunded the additional 5% I will run it for a month. Hope this helps Ed " We've got 10+ orders already through the group buy, so everyone gets 10% off! Thanks to everyone who jumped on board (or off the cliff, or over the fence)! Selection info from last year's thread: 914 models are available in the following configurations: 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. Thanks! |
Beebo Kanelle |
Feb 11 2019, 02:17 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
Which model is the correct one for '74 2.0 w/ stock D-Jet?
Is it the 123\PORSCHE-4-R-V ? |
914_teener |
Feb 11 2019, 02:19 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Ed at Ignition123USA has kindly agreed to give us a discounted price again this year. Here is his PM to me: "Hi Matt Sure we can do a group buy. I will set up the code 914GB19 It will give you 5% off If it reaches 10 customers you will be refunded the additional 5% I will run it for a month. Hope this helps Ed " So I believe that means we will get 10% off as long as we have at least 10 people. The code is now live. I know there was a lot of information on last year's thread about the various models. If anybody wants to summarize them on this thread, please feel free to do so. Thanks! I'll dispel high temperatures as a potential issue. I have ran my car in over 115 degree heat with no issue and without the car skipping a beat with exception of my parched throat and sweaty....... back. This dizzy is great and well worth not having issues with trigger points...broken advance diaphragms....points...condensors...ect. No affiliation. |
mobymutt |
Feb 11 2019, 02:28 PM
Which model is the correct one for '74 2.0 w/ stock D-Jet? Is it the 123\PORSCHE-4-R-V ? I'm afraid to answer anything, but the old thread has lots of info: http://www.914world.com/bbs2/index.php?sho...318153&st=0 Or call 123ignitionUSA directly. |
914Sixer |
Feb 11 2019, 02:29 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Tried to order and discount does NOT work. No answer on phone but I left message.
914_teener |
Feb 11 2019, 02:36 PM
Which model is the correct one for '74 2.0 w/ stock D-Jet? Is it the 123\PORSCHE-4-R-V ? For stock D-jet yes. You can order it with/without vacuum advance. If you get the -V model use ported vaccum if you have it. Not sure if the 75 TB has one since I have a 73 and it has both ported and manifold Vac. Download the manual to see which dip-switch number to use for your year. The manual will list that. Give him a while to setup the GB number....that same thing happened last time. He'll want to make sure after one month how many people there are to confirm orders at what % discount. Carry on. |
mobymutt |
Feb 11 2019, 02:42 PM
Tried to order and discount does NOT work. No answer on phone but I left message. I left a message earlier, and Ed did respond via text. He will likely get back to you shortly, or try texting him at that number. Otherwise, I've asked if he could monitor this thread and respond to any questions. |
mmichalik |
Feb 11 2019, 06:14 PM
MikeM Group: Members Posts: 689 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
Tried to order and discount does NOT work. No answer on phone but I left message. I left a message earlier, and Ed did respond via text. He will likely get back to you shortly, or try texting him at that number. Otherwise, I've asked if he could monitor this thread and respond to any questions. Cool! I sent an email out to them asking about the Bluetooth version and haven't received a response so, hopefully he'll take a look here. Thanks everyone for all the input and the GB setup! Mike |
123ignitionusa |
Feb 11 2019, 07:31 PM
Member Group: Members Posts: 62 Joined: 22-January 16 From: Ohio Member No.: 19,587 Region Association: North East States |
[quote name='Beebo Kanelle' date='Feb 11 2019, 04:17 PM' post='2688264']
Which model is the correct one for '74 2.0 w/ stock D-Jet? Is it the 123\PORSCHE-4-R-V ? [/quote All cars running D-jet must use Porsche 4-R-V-IE Hope this helps Ed |
123ignitionusa |
Feb 11 2019, 07:48 PM
Amphicar770 |
Feb 12 2019, 08:24 AM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Hmm, will be interesting to see if this gets 10 takers. I should have gone in on the original 10-15% group buy but was in a financial crunch at that time.
mobymutt |
Feb 12 2019, 09:01 AM
Amphicar770 |
Feb 12 2019, 11:13 AM
Hmm, will be interesting to see if this gets 10 takers. I should have gone in on the original 10-15% group buy but was in a financial crunch at that time. I'll try to keep a current count on the first post. Thanks. I'm on the fence on this one. Probably would not install before Spring (we are currently covered in ice). Thus, for a 5% discount, that you may or may not receive, might be more prudent to wait. |
mobymutt |
Feb 12 2019, 11:17 AM
Hmm, will be interesting to see if this gets 10 takers. I should have gone in on the original 10-15% group buy but was in a financial crunch at that time. I'll try to keep a current count on the first post. Thanks. I'm on the fence on this one. Probably would not install before Spring (we are currently covered in ice). Thus, for a 5% discount, that you may or may not receive, might be more prudent to wait. We get the 5% for sure, but we only get the 10% if we go over 10 people. |
mmichalik |
Feb 12 2019, 02:30 PM
Just ordered mine. So, there's at least one confirmed.
123ignitionusa |
Feb 12 2019, 03:36 PM
Gentlemen
Count is two. Additionally if someone orders two or more it will go toward the count. I will ship out as they are ordered. You guys automatically get 5% When you hit 9 I will change the coupon value to 10%. And refund the first nine buyers the additional percentage. Hope this helps Ed |
mobymutt |
Feb 12 2019, 08:23 PM
My order is placed. 3 down, 7 to go!
914Sixer |
Feb 12 2019, 09:13 PM
Ordered mine this morning.
HansJan |
Feb 12 2019, 09:34 PM
Member Group: Members Posts: 394 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Looking to purchase the Bluetooth model, because the engine is not stock.
Engine is: 4-Cylinders (103mm) 2.3L. Not original Cam. Dual EMPI 44mm Carbs (without vacuum) Current distributor is 009. The real problem with this car is its owner (me). Tried to set the timing once (with my son keeping the RPM's at 3K). I couldn't see anything, got confused, so I left it where it was. Could the Bluetooth distributor be too confusing for me? Do we keep the same coil? When ordering, do we also need to order the spacer? The plan is to purchase this thing, and then lean heavily onto this community to get the car running again. This strategy has worked in the past. |
Amphicar770 |
Feb 12 2019, 11:25 PM
Hmm, will be interesting to see if this gets 10 takers. I should have gone in on the original 10-15% group buy but was in a financial crunch at that time. I'll try to keep a current count on the first post. Thanks. I'm on the fence on this one. Probably would not install before Spring (we are currently covered in ice). Thus, for a 5% discount, that you may or may not receive, might be more prudent to wait. We get the 5% for sure, but we only get the 10% if we go over 10 people. Thanks for clarifying. That seems better. |
Lo-Fi Version | Time is now: 26th April 2024 - 10:53 AM |
