123 Distributor group buy (Feb 2019), *** 10% discount, extended to March 24th *** |
mobymutt |
Feb 11 2019, 01:57 PM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Ed at Ignition123USA has kindly agreed to give us a discounted price again this year.
Here is his PM to me: "Hi Matt Sure we can do a group buy. I will set up the code 914GB19 It will give you 5% off If it reaches 10 customers you will be refunded the additional 5% I will run it for a month. Hope this helps Ed " We've got 10+ orders already through the group buy, so everyone gets 10% off! Thanks to everyone who jumped on board (or off the cliff, or over the fence)! Selection info from last year's thread: 914 models are available in the following configurations: 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. Thanks! |
914Sixer |
Feb 11 2019, 02:29 PM
914 Guru Group: Members Posts: 8,875 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Tried to order and discount does NOT work. No answer on phone but I left message.
mobymutt |
Feb 11 2019, 02:42 PM
Tried to order and discount does NOT work. No answer on phone but I left message. I left a message earlier, and Ed did respond via text. He will likely get back to you shortly, or try texting him at that number. Otherwise, I've asked if he could monitor this thread and respond to any questions. |
mmichalik |
Feb 11 2019, 06:14 PM
MikeM Group: Members Posts: 693 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
Tried to order and discount does NOT work. No answer on phone but I left message. I left a message earlier, and Ed did respond via text. He will likely get back to you shortly, or try texting him at that number. Otherwise, I've asked if he could monitor this thread and respond to any questions. Cool! I sent an email out to them asking about the Bluetooth version and haven't received a response so, hopefully he'll take a look here. Thanks everyone for all the input and the GB setup! Mike |
Lo-Fi Version | Time is now: 5th May 2024 - 05:27 AM |
