123 Distributor group buy (Feb 2019), *** 10% discount, extended to March 24th *** |
mobymutt |
Feb 11 2019, 01:57 PM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Ed at Ignition123USA has kindly agreed to give us a discounted price again this year.
Here is his PM to me: "Hi Matt Sure we can do a group buy. I will set up the code 914GB19 It will give you 5% off If it reaches 10 customers you will be refunded the additional 5% I will run it for a month. Hope this helps Ed " We've got 10+ orders already through the group buy, so everyone gets 10% off! Thanks to everyone who jumped on board (or off the cliff, or over the fence)! Selection info from last year's thread: 914 models are available in the following configurations: 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. Thanks! |
Amphicar770 |
Feb 12 2019, 08:24 AM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Hmm, will be interesting to see if this gets 10 takers. I should have gone in on the original 10-15% group buy but was in a financial crunch at that time.
mobymutt |
Feb 12 2019, 09:01 AM
Amphicar770 |
Feb 12 2019, 11:13 AM
Hmm, will be interesting to see if this gets 10 takers. I should have gone in on the original 10-15% group buy but was in a financial crunch at that time. I'll try to keep a current count on the first post. Thanks. I'm on the fence on this one. Probably would not install before Spring (we are currently covered in ice). Thus, for a 5% discount, that you may or may not receive, might be more prudent to wait. |
mobymutt |
Feb 12 2019, 11:17 AM
Hmm, will be interesting to see if this gets 10 takers. I should have gone in on the original 10-15% group buy but was in a financial crunch at that time. I'll try to keep a current count on the first post. Thanks. I'm on the fence on this one. Probably would not install before Spring (we are currently covered in ice). Thus, for a 5% discount, that you may or may not receive, might be more prudent to wait. We get the 5% for sure, but we only get the 10% if we go over 10 people. |
Lo-Fi Version | Time is now: 5th May 2024 - 01:53 PM |
