123 Distributor group buy (Feb 2019), *** 10% discount, extended to March 24th *** |
mobymutt |
Feb 11 2019, 01:57 PM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Ed at Ignition123USA has kindly agreed to give us a discounted price again this year.
Here is his PM to me: "Hi Matt Sure we can do a group buy. I will set up the code 914GB19 It will give you 5% off If it reaches 10 customers you will be refunded the additional 5% I will run it for a month. Hope this helps Ed " We've got 10+ orders already through the group buy, so everyone gets 10% off! Thanks to everyone who jumped on board (or off the cliff, or over the fence)! Selection info from last year's thread: 914 models are available in the following configurations: 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. Thanks! |
BeatNavy |
Feb 13 2019, 01:54 PM
They recommend using a new coil. In theory, you should not have to if yours is serviceable, but it is recommended.
There is good info in this thread (or specifically at this post: http://www.914world.com/bbs2/index.php?s=&...&p=2545698) Also, spacer comes with the unit. You don't have to purchase separately. These things can be slightly tricky to set up initially, but once you've got 'em they are rock solid. |
914_teener |
Feb 13 2019, 03:41 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
They recommend using a new coil. In theory, you should not have to if yours is serviceable, but it is recommended. There is good info in this thread (or specifically at this post: http://www.914world.com/bbs2/index.php?s=&...&p=2545698) Also, spacer comes with the unit. You don't have to purchase separately. These things can be slightly tricky to set up initially, but once you've got 'em they are rock solid. Interesting reading through this thread again. Main thing I saw was understanding how vacuum advance works. For timing advance the source of the vacuum needs to be "ported" vacuum and not manifold vacuum. So on the TB it is the port just on the inside of the intake side. This will produce advance on part load. There are some cool threads that can be "Goggled" on the subject. |
Lo-Fi Version | Time is now: 5th May 2024 - 06:21 AM |
