123 Distributor group buy (Feb 2019), *** 10% discount, extended to March 24th *** |
mobymutt |
Feb 11 2019, 01:57 PM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Ed at Ignition123USA has kindly agreed to give us a discounted price again this year.
Here is his PM to me: "Hi Matt Sure we can do a group buy. I will set up the code 914GB19 It will give you 5% off If it reaches 10 customers you will be refunded the additional 5% I will run it for a month. Hope this helps Ed " We've got 10+ orders already through the group buy, so everyone gets 10% off! Thanks to everyone who jumped on board (or off the cliff, or over the fence)! Selection info from last year's thread: 914 models are available in the following configurations: 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. Thanks! |
Beebo Kanelle |
Feb 11 2019, 02:17 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
Which model is the correct one for '74 2.0 w/ stock D-Jet?
Is it the 123\PORSCHE-4-R-V ? |
123ignitionusa |
Feb 11 2019, 07:31 PM
Member Group: Members Posts: 62 Joined: 22-January 16 From: Ohio Member No.: 19,587 Region Association: North East States |
[quote name='Beebo Kanelle' date='Feb 11 2019, 04:17 PM' post='2688264']
Which model is the correct one for '74 2.0 w/ stock D-Jet? Is it the 123\PORSCHE-4-R-V ? [/quote All cars running D-jet must use Porsche 4-R-V-IE Hope this helps Ed |
HansJan |
Feb 13 2019, 06:46 PM
Member Group: Members Posts: 394 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Ed,
I just ordered mine (Order #1769). But the checkout process went soo quick (with Apple Pay) that I was not able to insert the group buy code. (IMG:style_emoticons/default/headbang.gif) Could you still apply the discount please? Br, Hans Jan |
123ignitionusa |
Feb 13 2019, 11:28 PM
Yes I will cover that for you. The GB is now at 6 and will soon hit 10 I will process your discount when the target of 10 is hit. If for some odd reason we don't make 10 you will still get the 5%.
Hope this helps Ed Ed, I just ordered mine (Order #1769). But the checkout process went soo quick (with Apple Pay) that I was not able to insert the group buy code. (IMG:style_emoticons/default/headbang.gif) Could you still apply the discount please? Br, Hans Jan |
Lo-Fi Version | Time is now: 5th May 2024 - 11:16 AM |
