123 Distributor group buy (Feb 2019), *** 10% discount, extended to March 24th *** |
mobymutt |
Feb 11 2019, 01:57 PM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Ed at Ignition123USA has kindly agreed to give us a discounted price again this year.
Here is his PM to me: "Hi Matt Sure we can do a group buy. I will set up the code 914GB19 It will give you 5% off If it reaches 10 customers you will be refunded the additional 5% I will run it for a month. Hope this helps Ed " We've got 10+ orders already through the group buy, so everyone gets 10% off! Thanks to everyone who jumped on board (or off the cliff, or over the fence)! Selection info from last year's thread: 914 models are available in the following configurations: 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. Thanks! |
settador |
Mar 21 2019, 05:37 PM
Newbie Group: Members Posts: 31 Joined: 16-May 05 From: Lee, NH Member No.: 4,086 Region Association: None |
The following thread has a very helpful write up regarding vacuum advance. It helps explain the graphs Ed posted in response to my query. I checked my Webers for vacuum ports and fortunately they are there. Ed also offered a good explanation via telephone. I haven't installed either distributor as I haven't built either engine yet, so I can't offer anything further at this time. Hope the link helps.
Dan http://www.914world.com/bbs2/index.php?showtopic=162620 |
914_teener |
Apr 2 2019, 05:20 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
The following thread has a very helpful write up regarding vacuum advance. It helps explain the graphs Ed posted in response to my query. I checked my Webers for vacuum ports and fortunately they are there. Ed also offered a good explanation via telephone. I haven't installed either distributor as I haven't built either engine yet, so I can't offer anything further at this time. Hope the link helps. Dan http://www.914world.com/bbs2/index.php?showtopic=162620 Yep....saw that thread a while back. Pay close attention in that for a stock FI 914 and depending on what year they had both manifold and ported vaccum for the dizzy pot. When I did my 73 is used ported for the vaccum advance and the car performed flawlessly. I know that this subject keeps coming up even though the manual that is provided specifies what to use for which setting. This is on the D-jet system that I know. Still it is a good read and loosely defines the history of why and how it is used. |
Lo-Fi Version | Time is now: 5th May 2024 - 01:05 PM |
