123 Distributor group buy (Feb 2019), *** 10% discount, extended to March 24th *** |
mobymutt |
Feb 11 2019, 01:57 PM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Ed at Ignition123USA has kindly agreed to give us a discounted price again this year.
Here is his PM to me: "Hi Matt Sure we can do a group buy. I will set up the code 914GB19 It will give you 5% off If it reaches 10 customers you will be refunded the additional 5% I will run it for a month. Hope this helps Ed " We've got 10+ orders already through the group buy, so everyone gets 10% off! Thanks to everyone who jumped on board (or off the cliff, or over the fence)! Selection info from last year's thread: 914 models are available in the following configurations: 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. Thanks! |
michael7810 |
Apr 6 2019, 04:05 PM
Senior Member Group: Members Posts: 1,080 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I installed the Bluetooth unit on my 1911cc, webcam, dual IDF 40s s week. Took a couple days to get it sorted out as I had a few DAO-induced problems. Took it for a drive and head temps seemed to run cooler than usual on this particular drive but I may have been taking it easy. Very happy with the way the car runs and features of the distributor. Here’s what I learned:
1. The 123 wires up to MSD ignition exactly like the old Pertronix unit 2. MSD Blaster 2 coil resistance is too low (<1 Ohm). I installed a new Bosch blue coil 3. There are 10 video tutorials on the 123 website. I found them very helpful for my understanding how it works. 4. You can only change the curves with the ignition ON and engine NOT running 5. You can see what the unit is doing and make temporary advance changes via the Tune feature with the engin running 6. Follow the manual for paring the unit to your device the first time. Once pared here’s how to use it 6a. Turn ignition on first then open the App if you want to change curves. You can start the car after changing the curves without cycling power or reopening the App. Change the curves per the manual but when you are finished hit DONE and then WRITE or the 123 will not see the new data. If you futz with the curves and want to go back to what you started with hit DONE and then READ and the App will display what is stored in the 123 6b. Start engine first then open App if you want to drive and use the Tune feature. 7. When you open the App, make sure it connects AND reads the distributor data. You’ll see it on the App when connecting/reading. 8. To use Tune, hit Tune on the dashboard screen and use the arrows to advance or retard up to 10 degrees. This shifts the entire curve, kinda like changing the basic timing from, in my case from TDC to +/- 10 degrees. The Tune data is not stored in the 123. Once you hit TUNE again to get out of tune mode your changes disappear. 9. My curves are below. I set my timing to TDC and use the 123 to set the advance 10. Be careful handling your phone when the dashboard is open. I accidentally got into TUNE mode and retarded my timing 10 degrees TWICE during a 90 minute drive. I highly recommend a copilot to operate the device while driving. I’m sure there’s more. If I think of anything else I’ll edit this post. Cheers |
Lo-Fi Version | Time is now: 5th May 2024 - 03:52 AM |
