Lifts, 2 Post Hydraulic Lift Questions |
sb914 |
Apr 3 2019, 04:29 PM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
914-300Hemi |
Apr 3 2019, 09:41 PM
Senior Member Group: Members Posts: 1,356 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
I just placed an order for a MaxJax 2 post lift. Looked at scissor lifts but didn’t like the weight, extra delivery fees and i had to build ramps.
It gets delivered next week. (IMG:style_emoticons/default/piratenanner.gif) |
Krieger |
Apr 3 2019, 10:41 PM
Advanced Member Group: Members Posts: 4,703 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Welcome back Elliot! You've been missed 'my little chickadee'. (IMG:style_emoticons/default/cheer.gif) I'd recognize that scoop anywhere! |
mb911 |
Apr 4 2019, 05:46 AM
914 Guru Group: Members Posts: 6,814 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I just placed an order for a MaxJax 2 post lift. Looked at scissor lifts but didn’t like the weight, extra delivery fees and i had to build ramps. It gets delivered next week. (IMG:style_emoticons/default/piratenanner.gif) After having mine for a few weeks I can tell you this. The hoses are really in the way. I need to find a way to cover them like what they do for trade shows and electrical cords.. |
76-914 |
Apr 4 2019, 08:34 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,492 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'm lucky there. My hose slips into the recess of the slabs expansion joint so the hose is semi recessed. The best accessory I have found for my Max Jack are the Harbor Freight small furniture dollies. They allow me to use the 4" extensions that come with it. Raise the car 3-4" then lower onto the dollies. Once on the dolly the extensions can be fitted. Why furniture dollies instead of blocks. Try it and you'll find out. Bottom line: Any lift is better than no lift. Get what you can afford and whatever fits. (IMG:style_emoticons/default/beerchug.gif)
mlindner |
Apr 4 2019, 12:15 PM
Senior Member Group: Members Posts: 1,514 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
914_teener |
Apr 4 2019, 12:24 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Ben, just get a cement blade for your circular saw. Saw two groves 3/4 inch apart and 3/4 inch deep, hit with hammer/chisel. I ran mine then filled channel with flexible cement caulk. See bottom right corner gives you a little peak of the flat floor. Best, Mark Curious...... What is the capacity of that lift? |
Apr 4 2019, 12:26 PM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Hose Protector Ramp - sold on Amazon
mlindner |
mlindner |
Apr 4 2019, 12:29 PM
914 teener. Bendpak, 6,000 lbs. love it.
mlindner |
Apr 4 2019, 01:11 PM
ctc911ctc, just looking at your garage size again....a two post lift as nice as they are will take up much of your space with the car in. A scissor lift would give you that space back but limited as to the height. For 911s and 914s the scissor is especially nice since there is nothing in the middle of the car (exhaust, drive line etc.) Have fun, Mark
mlindner |
Apr 4 2019, 01:29 PM
Just noticed, two out of the three two post lifts mentioned are to wide for your garage....over 120 inch.
mb911 |
Apr 4 2019, 03:08 PM
@mlinder
I suppose I could do that.. Not a bad idea.. |
914_teener |
Apr 4 2019, 03:26 PM
ctc911ctc, just looking at your garage size again....a two post lift as nice as they are will take up much of your space with the car in. A scissor lift would give you that space back but limited as to the height. For 911s and 914s the scissor is especially nice since there is nothing in the middle of the car (exhaust, drive line etc.) Have fun, Mark Do you think with a 987.1 I could still get at the water pump in the front of the engine? Thanks for those pics. |
Dredwin |
Apr 4 2019, 03:50 PM
Member Group: Members Posts: 71 Joined: 21-December 13 From: Colorado Springs Member No.: 16,783 Region Association: Rocky Mountains |
I embraced my hose...bought a pool noodle, cut it open and ran the hose through it. I was worried I'd step on the hose and puncture it so at least the pool noodle protects it. I have the scissor lift though and wanted the flexibility of moving the lift around (and wanting to cut the floor up).
mlindner |
Apr 5 2019, 05:12 AM
914 teener, good question and I do have a Cayman.....I have not done the water pump or belts yet. I believe with the extra work of putting the extension on and getting the car another 8 inch above the lift it would work. The few pictures I have of the Cayman were just to clean last year before the parade. Best, Mark
Mark Henry |
Apr 5 2019, 06:10 AM
ctc911ctc, just looking at your garage size again....a two post lift as nice as they are will take up much of your space with the car in. A scissor lift would give you that space back but limited as to the height. For 911s and 914s the scissor is especially nice since there is nothing in the middle of the car (exhaust, drive line etc.) Have fun, Mark Do you think with a 987.1 I could still get at the water pump in the front of the engine? Thanks for those pics. I'd go for 2 post like maxjack on the water cooleds, crapload of stuff runs down the center. I the took the tranny and driveshaft out of a C4S yesterday morning, IMS solution, no way could you do that with a table lift. Today I have to replace the clutch slave cyl in another C4S, PITA getting my big mitts up there even with a 2 post. |
mlindner |
Apr 5 2019, 07:01 AM
I agree Mark, with doing that much work...trans, engines a two post is a must.
Hans Zupp |
Apr 25 2019, 09:34 AM
Yugo Driver Group: Members Posts: 9 Joined: 11-January 11 From: Yugoslavia Member No.: 12,577 Region Association: None |
Krieger |
Sep 28 2019, 10:43 AM
Now I am considering the move to the two post lift. I have had an EZ car lift for at least 10 years, but I want to stop rolling around on the ground and stand or as close to that as possible. I have a good size garage that is 25'×25' with 10' high ceilings. What are the electrical requirements for these lifts? Is 110 enough?
Lo-Fi Version | Time is now: 28th April 2024 - 01:30 AM |
