Fuel Tank Frustration!, Tank is Sitting too High |
Blue6 |
Feb 15 2019, 09:15 PM
Senior Member Group: Members Posts: 1,033 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
Now that this got straightened out, I’ll piggy back on this thread. My rubber isn’t fitting correctly either. I know posts are useless without pics. Anyone want a pic. (IMG:style_emoticons/default/biggrin.gif) Show us what you got! I’ve got to get with SirAndy. Can’t figure out how to resize this whopper to make it fit the format. (IMG:style_emoticons/default/smile.gif) |
mlindner |
Feb 16 2019, 09:37 AM
Senior Member Group: Members Posts: 1,512 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Feb 16 2019, 09:58 AM
rhodyguy |
Feb 16 2019, 10:51 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
What do the 2 screws on the tops of the wheelwells do?
mlindner |
Feb 16 2019, 10:55 AM
Good eye rhodyguy......I made fender liners for under the GT fenders, so a few fasteners had to show, will paint later. Mark
914_7T3 |
Feb 18 2019, 09:36 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
So it turns out the fuel tank was sitting fine and the expansion tank is the culprit. It literally "Expanded" during powder coating.
(IMG:style_emoticons/default/WTF.gif) No wonder it would not fit. |
Feb 18 2019, 09:39 PM
Maybe they put a plug on the ends to keep the powder out and the hot air blew it up. At least it's an easy part to replace.
sb914 |
Feb 19 2019, 07:23 AM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
So it turns out the fuel tank was sitting fine and the expansion tank is the culprit. It literally "Expanded" during powder coating. (IMG:style_emoticons/default/WTF.gif) No wonder it would not fit. I think I might have one . If you want it it’s yours, I’ll look later if you want it . |
marksteinhilber |
Feb 19 2019, 12:29 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
Just draw a vacuum on it and suck it back down to the right shape...
On the rubbers, just use some lube. it lets things slide into position and you can feel when they fit best. I never tape my rubbers on. Not fun when there's too much friction either. Sometimes the carpet landing strips may be too thick and it wont drop in all the way.... |
914_7T3 |
Feb 19 2019, 12:32 PM
So it turns out the fuel tank was sitting fine and the expansion tank is the culprit. It literally "Expanded" during powder coating. (IMG:style_emoticons/default/WTF.gif) No wonder it would not fit. I think I might have one . If you want it it’s yours, I’ll look later if you want it . Thanks @sb914 Picking up another expansion tank today nearby so probably will not need, but will reach out if this one looks wonky. |
dr914@autoatlanta.com |
Feb 19 2019, 12:42 PM
914 Guru Group: Members Posts: 7,817 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
pads should be a bit lower, and maybe use some silicone grease
burton73 |
Feb 19 2019, 01:42 PM
burton73 Group: Members Posts: 3,498 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Just draw a vacuum on it and suck it back down to the right shape... On the rubbers, just use some lube. it lets things slide into position and you can feel when they fit best. I never tape my rubbers on. Not fun when there's too much friction either. Sometimes the carpet landing strips may be too thick and it wont drop in all the way.... Jeffrey, I have a high vacuum pump if you want to bring it to the shop and give it a try. Bob B (IMG:style_emoticons/default/wacko.gif) |
914_7T3 |
Feb 19 2019, 03:38 PM
Just draw a vacuum on it and suck it back down to the right shape... On the rubbers, just use some lube. it lets things slide into position and you can feel when they fit best. I never tape my rubbers on. Not fun when there's too much friction either. Sometimes the carpet landing strips may be too thick and it wont drop in all the way.... Jeffrey, I have a high vacuum pump if you want to bring it to the shop and give it a try. Bob B (IMG:style_emoticons/default/wacko.gif) Totally, I have a temporary that I picked up today, just to keep things moving and mine has been PC'd already so its worth a shot! |
Lo-Fi Version | Time is now: 26th April 2024 - 01:24 AM |
