Fuel Line Destination, Hook-up, Engine Comp. |
Chip |
Feb 15 2019, 07:32 PM
Member Group: Members Posts: 125 Joined: 1-April 17 From: Brigham City, UT Member No.: 20,986 Region Association: Intermountain Region |
(IMG:style_emoticons/default/smash.gif) '73 1.7, D-Injection, fuel pump moved to front.
Working with the two fuel lines that come from the tank thru the tunnel. One is large, one small. Since most of the lines in the front were corroded and full of tar, (all replaced), I must continue to clean/replace them at the engine site. Car sat for over 30 yrs. Correct me please, brother Haynes is not very clear. Large fuel line connects to (1) Pressure Regulator, Cold start Valve and Injectors. Not sure of location of Pressure regulator. All the regulators/pumps mixers look alike. I think it is near the injector, passenger side, mixing tube. Small line connects to Pressure Regulator. Thanks for your help! |
ndfrigi |
Feb 15 2019, 09:20 PM
this is for ljet 1.8 but you get the idea
rhodyguy |
Feb 16 2019, 08:15 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Bowlsby.net
Mark Henry |
Feb 16 2019, 08:31 AM
Tank with screen, to filter, to pump, to big line, to 3/4 injectors, to cold start valve, to 1/2 injectors and finally to the regulator and return line.
All hose in the high pressure loop (pump to regulator) must be FI hose, I just use FI hose for the whole system. Always use FI hose clamps, NEVER the standard worm gear style hose clamps. |
Chip |
Feb 16 2019, 12:45 PM
Chip |
Feb 16 2019, 12:53 PM
Tank with screen, to filter, to pump, to big line, to 3/4 injectors, to cold start valve, to 1/2 injectors and finally to the regulator and return line. All hose in the high pressure loop (pump to regulator) must be FI hose, I just use FI hose for the whole system. Always use FI hose clamps, NEVER the standard worm gear style hose clamps. Good! Some hose clamps were slotted, worm gear. I replaced those with solid, FI clamps. Used many of the original clamps. They have a tiny VW stamp on the band. Thanks for this helpful reply! |
sixnotfour |
Feb 17 2019, 01:32 AM
914 Wizard Group: Members Posts: 10,411 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
large tank to pump= supply
large in tunnel to injectors = delivery small from regulator drivers side to in tunnel = return up front under tank return and bypass- T = return to tank Attached image(s) |
Chip |
Feb 17 2019, 01:15 PM
large tank to pump= supply large in tunnel to injectors = delivery small from regulator drivers side to in tunnel = return up front under tank return and bypass- T = return to tank Great help! Getting near to turning the key after 30+ years. Now. need to put some Magic Oil in the cylinders. How do I get to them? And how can I hand-crank the engine/ |
Chip |
Feb 17 2019, 01:26 PM
Lo-Fi Version | Time is now: 26th April 2024 - 11:58 AM |
