'73 1.7, D-Injection, fuel pump moved to front.
Working with the two fuel lines that come from the tank thru the tunnel. One is large, one small. Since most of the lines in the front were corroded and full of tar, (all replaced), I must continue to clean/replace them at the engine site. Car sat for over 30 yrs.
Correct me please, brother Haynes is not very clear. Large fuel line connects to (1) Pressure Regulator, Cold start Valve and Injectors. Not sure of location of Pressure regulator. All the regulators/pumps mixers look alike. I think it is near the injector, passenger side, mixing tube.
Small line connects to Pressure Regulator.
Thanks for your help!
