1970, 914-6, Wiring Diagram |
Dario |
Feb 16 2019, 03:36 PM
Newbie Group: Members Posts: 10 Joined: 21-June 15 From: Florida Member No.: 18,875 Region Association: None |
Can anyone help with a wiring diagram for the 1970, 914-6.
trying to trace the two brown wires that run from the contact switch for the key/door buzzer. any and all help appreciated. Thanks |
dr914@autoatlanta.com |
Feb 16 2019, 03:39 PM
914 Guru Group: Members Posts: 7,832 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the early cars actually run power to the door switch, which screws things up for trying to easily solve the buzzer routing, also the euro cars are different than the usa cars. The wiring diagram for this is the same as the 70-72 four cylinder cars Dario, and those diagrams are commonly available on the internet
Can anyone help with a wiring diagram for the 1970, 914-6. trying to trace the two brown wires that run from the contact switch for the key/door buzzer. any and all help appreciated. Thanks |
toolguy |
Feb 16 2019, 03:58 PM
Senior Member Group: Members Posts: 1,267 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Porsche factory manual book 9 Chapter 3-6-8.2
the 2 brown wires [one from each door] go to the contact plug on the ignition switch It's a 2 prong connector . . the other side of the connector goes to the buzzer relay which is powered by fuse 11 by my notes. . Here is the manual Attached image(s) |
gereed75 |
Feb 16 2019, 04:58 PM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Toolguy, meticulous as usual!
R8CERX |
Feb 16 2019, 08:13 PM
2014 New year resolution: To get along with Woody... Group: Members Posts: 606 Joined: 5-June 13 From: California Member No.: 15,972 Region Association: Southern California |
Porsche factory manual book 9 Chapter 3-6-8.2 the 2 brown wires [one from each door] go to the contact plug on the ignition switch It's a 2 prong connector . . the other side of the connector goes to the buzzer relay which is powered by fuse 11 by my notes. . Here is the manual YOU ARE AWESOME!! always helping out! Long time no see! Felix |
Lo-Fi Version | Time is now: 4th May 2024 - 04:26 AM |
