Engine cooling, Thermostat bellows / Cooling flaps |
RolinkHaus |
Feb 17 2019, 10:55 AM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
Question:
If I only drive my 914 in the summer at shows and the track, do I really need my thermostat bellows? Running headers, no heat, working on a oil cooler.... |
worn |
Feb 17 2019, 11:05 AM
can't remember Group: Members Posts: 3,148 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Question: If I only drive my 914 in the summer at shows and the track, do I really need my thermostat bellows? Running headers, no heat, working on a oil cooler.... Maybe not, and I know they are hard to find. Might be easier on the motor during start up. Also, you want the flaps and you need them to be open when the engine is hot. The flaps as I recall direct air flow to the oil cooler. |
Mark Henry |
Feb 17 2019, 11:30 AM
Awesome PowderCoating has T-stats.
Yes, you have to keep the flaps. You want the engine up to running temp ASAP, especially important for cool northern mornings, less wear, better mileage, etc. Would you run no t-stat on a water cooled car? It's there for the same reasons. BTW VW T-stats only fail in the open position. |
RolinkHaus |
Feb 17 2019, 11:47 AM
Could these flaps be modified to pump air in constantly using the blower motor? In the future, I plan to rebuild and modify my 2.4 cis (IMG:style_emoticons/default/aktion035.gif)
Mark Henry |
Feb 17 2019, 11:54 AM
Not sure what you're asking, an electric fan pushes nothing compared to the cooling fan and the cooling fan pressure would likely push past an 12v fan.
RolinkHaus |
Feb 17 2019, 12:33 PM
Thank so for the info
Lo-Fi Version | Time is now: 27th April 2024 - 01:12 PM |
