Spanish 914-6 Outlaw Build, Introduction |
Volkstuning |
Feb 25 2019, 12:13 PM
Newbie Group: Members Posts: 8 Joined: 8-February 19 From: Estepona Member No.: 22,859 Region Association: None |
Hi. I run Volkstuning in Southern Spain and we have just started a 914 GT outlaw build. Our base car is a 1971 european model. We have a freshshly built 2.4 911 engine ready to go in this car. The plan is to a dry build, get all the running gear dial in, then drive train. Once we are happy with all the mods we will take her apart and go for the full works. This will probably be the first of many posts.
Attached thumbnail(s) |
horizontally-opposed |
Feb 25 2019, 12:21 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
(IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welcome.png)
Way cool, and glad to see you here. Greetings from San Francisco to Estepona! |
dr914@autoatlanta.com |
Feb 25 2019, 12:22 PM
914 Guru Group: Members Posts: 7,873 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you sure are starting off in the right way!
burton73 |
Feb 25 2019, 12:28 PM
burton73 Group: Members Posts: 3,531 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
ValcoOscar |
Feb 25 2019, 12:30 PM
Garage Life Group: Members Posts: 2,388 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/welcome.png)
One to watch.... Hope you realize you're entering an addiction phase with your GT project. Oscar |
Volkstuning |
Feb 25 2019, 12:35 PM
First challenge of many I am sure. we are using a mixture of SC hubs an vented cross drilled disks. together with boxter calipers. The original 914 has the smaller 4 bolt flange which is not compatible with the later SC drive flange which i believe is known as the small 6 flange, the large 6 flange being the one mounted to the turbos. My question is can I fit late cv joint 75<>86 to the drive shaft originaly fitted to the 914? are the interior splines compatible? I dont have any 911 cvoint to habd and would have to order some to see if it would work. All advice and information appreciated.
Volkstuning |
Feb 25 2019, 12:36 PM
Thank you.
Volkstuning |
Feb 25 2019, 12:38 PM
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/welcome.png) One to watch.... Hope you realize you're entering an addiction phase with your GT project. Oscar There are worse addictions to have |
Volkstuning |
Feb 25 2019, 12:39 PM
Feb 25 2019, 12:53 PM
914-6 GT in waiting Group: Members Posts: 19,294 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You should read these two threads on converting to 5 lug and CV upgrades. I believe these are the two best threads on the internet for understanding the conversion and what will fit. The only thing I can add is if you use later hubcentric hubs, you will need a 5mm spacer. If you use early hubs, no spacer is required. http://www.914world.com/bbs2/index.php?showtopic=105728 http://www.914world.com/bbs2/index.php?showtopic=91963 |
daytona |
Feb 25 2019, 01:13 PM
daytona Group: Members Posts: 435 Joined: 13-April 14 From: Ormond Beach, Florida Member No.: 17,249 Region Association: South East States |
Volkstuning |
Feb 25 2019, 01:29 PM
(IMG:style_emoticons/default/welcome.png) You should read these two threads on converting to 5 lug and CV upgrades. I believe these are the two best threads on the internet for understanding the conversion and what will fit. The only thing I can add is if you use later hubcentric hubs, you will need a 5mm spacer. If you use early hubs, no spacer is required. http://www.914world.com/bbs2/index.php?showtopic=105728 http://www.914world.com/bbs2/index.php?showtopic=91963 I did read the first article before getting stuck in. The second one is more relevant to what I am trying to achive. Going to ask some questions on that thread. |
mb911 |
Feb 25 2019, 01:39 PM
914 Guru Group: Members Posts: 6,858 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Let me know if I can help in anyway www.914-6werkshop.com |
rick 918-S |
Feb 25 2019, 01:50 PM
Hey nice rack! -Celette Group: Members Posts: 20,470 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Cairo94507 |
Feb 25 2019, 02:51 PM
Michael Group: Members Posts: 9,791 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
(IMG:style_emoticons/default/welcome.png) You have thrown your hat into a great ring. This is a terrific bunch of guys with more experience with 914's than anywhere else n the planet. Tons of threads regarding GT builds and I bet every issue you have a question about will have an answer here. Enjoy the journey. (IMG:style_emoticons/default/beerchug.gif)
914Sixer |
Feb 25 2019, 03:18 PM
914 Guru Group: Members Posts: 8,892 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I am using 911 SC rear hubs and stubs. You need the 5mm spacer on the inside of the hub to use the stock 914 rear wheel bearing. Your 911 SC stub axle is then correctly spaced. Use what ever rotor and caliper combo you want.
Spacer is available from Patrick MotorSports About $55. |
Feb 25 2019, 03:53 PM
I am using 911 SC rear hubs and stubs. You need the 5mm spacer on the inside of the stub to use the stock 914 rear wheel bearing. Your 911 SC stub axle is then correctly spaced. Use what ever rotor and caliper combo you want. Spacer is available from Patrick MotorSports About $55. I need a couple sets of those 5mm spacers. I was going to ask Ben if he could make some for less than PMS. @MB911 Attached image(s) |
mb911 |
Feb 25 2019, 04:58 PM
I am using 911 SC rear hubs and stubs. You need the 5mm spacer on the inside of the stub to use the stock 914 rear wheel bearing. Your 911 SC stub axle is then correctly spaced. Use what ever rotor and caliper combo you want. Spacer is available from Patrick MotorSports About $55. I need a couple sets of those 5mm spacers. I was going to ask Ben if he could make some for less than PMS. @MB911 I am sure that's a pretty easy part to make.. Any dimensions out there I can use? |
RolinkHaus |
Feb 25 2019, 05:18 PM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
Can't wait to see what your going to do with the 2.4 .
Valy |
Feb 25 2019, 06:06 PM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Hi. I run Volkstuning in Southern Spain and we have just started a 914 GT outlaw build. Our base car is a 1971 european model. We have a freshshly built 2.4 911 engine ready to go in this car. The plan is to a dry build, get all the running gear dial in, then drive train. Once we are happy with all the mods we will take her apart and go for the full works. This will probably be the first of many posts. Can you please take a lot of pictures before you take it apart? Many of us will appreciate the info in the pictures for documenting authentic European spec. What was the original color of the front and rear valance and side rocker panels? Is the car fuel injected or carbs? Pictures please. Dashboard pictures please. VIN pictures. Front trunk pictures Front and rear fog lights (if available). I'm sure others will jump on. Wellcome to the club! |
Lo-Fi Version | Time is now: 27th May 2024 - 08:55 AM |
