LED Headlight Bulb Failure, Less Than 6 Months Added Update |
914Sixer |
Feb 26 2019, 10:55 AM
I am noticing that LED bulbs are not holding up very well. Is it just the luck of the draw on quality control? I replaced all 4 bulbs on my truck. One had died this morning. I real PITA to replace because grill has to come out. 2nd set of bulbs this year.
I have also noticed the LED's at the house are dying early too. Just my bad luck? |
Chi-town |
Feb 26 2019, 11:20 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
They're real sensitive to voltage variations and heat.
timothy_nd28 |
Feb 26 2019, 11:21 AM
It's the reason why I've been holding off. Lots of heat and leadfree solder. Sorry to hear
76-914 |
Feb 26 2019, 11:24 AM
914Sixer |
Feb 26 2019, 12:17 PM
We have had some good cold snaps this winter., then the temperature jumps back to the low 70-80's .
Spoke |
Feb 26 2019, 12:24 PM
The actual LED component is probably good. With LED lights there's a lot of circuitry around the LED to make it work correctly. Heating and cooling, and vibrations are all bad for the LED circuitry.
Here's a BMW with some severe issues on the driver side brake lights. This Nissan has one LED out on the passenger side. The driver side brake/running LEDs are very dim on this Prius. Looks like all the LEDs are ok but the driving circuitry has issues. Some of the round truck type LEDs which are out or having issues: |
whitetwinturbo |
Feb 26 2019, 03:05 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
.........I see a lot of LED traffic lights with dead spots in SoCal (IMG:style_emoticons/default/blink.gif)
Mikey914 |
Feb 26 2019, 07:08 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I am noticing that LED bulbs are not holding up very well. Is it just the luck of the draw on quality control? I replaced all 4 bulbs on my truck. One had died this morning. I real PITA to replace because grill has to come out. 2nd set of bulbs this year. I have also noticed the LED's at the house are dying early too. Just my bad luck? If you bought then from us we will replace them. We went through rigorous testing before we brought on the ones we did. Just PM me if this is the case. Thanks, Mark |
914Sixer |
Feb 27 2019, 06:09 AM
None of the LED's I was speaking about came from 914 Rubber.
JmuRiz |
Feb 27 2019, 08:48 AM
914 Guru Group: Members Posts: 5,427 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
914Sixer, what brand leds were in the truck, just curious if they were full units or drop-in bulb replacements.
I've yet to install my sealed units on my 914 headlights or the board-units on the signal lights. |
914Sixer |
Feb 27 2019, 09:16 AM
Just bulb replacements, don't know brand on lights. Came from the local auto store.
pt_700 |
Feb 27 2019, 03:44 PM
Senior Member Group: Members Posts: 1,092 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
having similar issues with an led tail light module on my klr650 (big single cylinder dual sport motorcycle). it's supposed to flash 5 times upon application of the brake, then on solid.
works fine with the key on or at idle, not at any engine speed above... sounds like it's time for a new one... |
914Sixer |
Mar 12 2019, 09:19 AM
LED update. I ordered some of the (new ?) 4 element headlight replacements. At least now if one element fails you still have 3 that will work. These have 5 yr replacement. Going to try this go round.
Spoke |
Mar 12 2019, 10:57 AM
At least now if one element fails you still have 3 that will work. Good luck with the new lights. The 4 LEDs may be in some sort of series/parallel combination. Each white LED drops about 3V so one might be able to put 4 in series with some sort of current limiter. Or they are connected 2 in series (6V) with 2 parallel strings. |
914Sixer |
Mar 12 2019, 01:57 PM
Adding pictures of 2 element, then the last 2 of the 4 element. 4 element seems to produce more usable light.
Lo-Fi Version | Time is now: 17th May 2024 - 06:08 PM |
