Aftermarket FI, Requesting opinions! |
falcor75 |
Mar 5 2019, 08:05 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Mario at http://thedubshop.com/ makes his own Megasquirt based ecu tailored for making aircooled engines go EFI. Worth a look.
Mark Henry |
Mar 5 2019, 08:14 AM
Ian Stott Moncton Canada Ian, go with Mark to set up your SDS & I think you'll be really happy and not have to deal with the near vertical learning curve with a different system. Here's a link to my 2316 build--injectors for this engine/cam are "red top" 30 pound type--not sure if you'll need to go that big, but Mark will know. I can also share my fueling & spark curves on Excel spreadsheet if you want. http://www.914world.com/bbs2/index.php?sho...921&hl=dyno Ian's big problem with me is logistics....he lives 18+ hours away, one way. (IMG:style_emoticons/default/smile.gif) |
Chi-town |
Mar 5 2019, 10:22 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
No you're ranting about a system you have no fuchsing clue about or have ever used.
One I'm not one of the people ranting in this post, 'Im simply stating facts. I have actually used a SDS system and similar systems and they work ok if you're looking for basic functions. Sequential ignition and fuel control Great for fuel economy at 1000-3000rpm but seeing as you shouldn't lug a T4 below 3000rpm all but useless on a T4. You must not understand the benefits of this? Cylinder balance is just one of the advantages. Knock detection useless on a noisy aircooled engine, but SDS has this option Works quite well actually and can save your engine if you know how to use it. We use it on the current turbo Type 4 that I'm consulting on and it has saved their motor Built in Lamda control SDS has this, but you don't control a lambda, you or your ECU reads it There's more to Lambda than just reading a signal, the heater element control is one of the items in that group. Flex fuel capabilities honestly don't know, I only use pure gas 91, I did run E10 on my 1.8 no problem Here in the US we only get 10% ethanol fuel in most places. E85 does have performance gains if you know how to use it even in an N/A engine. Multiple trigger input styles (crank wheel, distributor, etc) SDS will run stock dizzy, MSD or crankfire. I believe now you could use a trigger wheel, COP, etc. It's got one 2 out of 6 items on the list (IMG:style_emoticons/default/laugh.gif) OEM sensor calibrations SDS works with some OEM, but again doesn't matter on a T4 and for aircooled SDS uses the stock bosch head temp sensor. Why not all? SDS has full data logging, real time and/or logged, plug it into a laptop if you like If it didn't I would have said just throw it in the trash. (IMG:style_emoticons/default/laugh.gif) [quote]I'm not just making blind statements as I am a paid data acquisition consultant and I have over two decades of experience with street and race vehicles.[/quote]" Good for you! How many VW/Porsche engines are you building right now? I'm building ten engines, three 996, four T4, two T1 and one 356. Seven are performance builds, I had to add my 6th engine stand. If you really want to compare personal achievements, I've built a ton of horizontally opposed engines (somewhere around 200) including VW, Porsche, and Subaru and made crazy power (1593whp 2JZ is my personal best). I said I don't tune cars for people, never said I didn't build them Here are some ECU manufacturers to start you on your research: Motec Link Haltec Pectal Emtron AEM[/quote] All require expensive dyno and tuning time, plus a steep learning curve. Most of those systems listed are way more money than SDS And in this case a basically stock engine, 2056 with a WEB #73 FI cam. Plus I know Ian (the OP) and I know he doesn't want to learn how to program a complex system. Begs the question why do you need "Engine management" for a simple pushrod 8 valve NA engine based on an 80 year old design? [/b] Actually the Link is cheaper than an SDS by a good margin ($800 vs $1200). Any Standalone ECU should always be tuned for the car it's installed on. You're spending a lot of money on a unit, don't you want to get the most out of it and make sure the tune is actually safe for your setup? If not, go buy some bolt on 40mm Webers and be done with it because it equates to about the same thing Newer ECUs are easy to seup. For example the Link software uses drop down menus for thing like triggers and sensor calibrations, it doesn't get much easier than that. They also have a huge support community which just like your SDS you can get a base map that will allow you to plug it in and start it up. I love how the car being old is an excuse not to use newer tech to make it better (IMG:style_emoticons/default/WTF.gif) @Ian Scott - If you want a SDS have at it, from your original post I thought you were looking for a list of options, sorry to gum up your thread. |
Mark Henry |
Mar 5 2019, 11:50 AM
OKay (IMG:style_emoticons/default/biggrin.gif)
One I'm not one of the people ranting in this post, 'Im simply stating facts. I have actually used a SDS system and similar systems and they work ok if you're looking for basic functions. I'm not going to play, but that's exactly what the OP wants. He wants "everytime you turn the key it runs", nothing more. He doesn't want or need bells and whistles. Bone stock 2.0 engine with (would be) stock Djet intake, SSI's, only upgrades are KB P&C 96mm, Web #73 FI cam (almost stock), SSI's and a CFR muffler. I doubt Ian will ever play with the values or want to. |
Chris914n6 |
Mar 5 2019, 11:57 AM
Jackstands are my life. Group: Members Posts: 3,341 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
SDS is the Windows XP laptop of Aftermarket FI. Sure it will work but you can get more features on modern hardware for half the $$ with anything else on the market.
That being said, the most important part is the tuner. So if Mark can provide a solution within your budget then that would be the best option. |
Mark Henry |
Mar 5 2019, 12:36 PM
Maybe you guys could help Ian trouble shoot his Ljet and then he doesn't need an aftermarket FI system.
I installed it, ran flawlessly, my 914's known good '74 Ljet system on a 2.0 914 engine. About a year or so later, just in the morning, it won't start. It cranks and cranks real good but won't catch. When I did it all new hoses including runners, cap and injector seals, head temp sensor, matching dizzy added pertronix. Like I said, worked flawlessly, I test drove it for two weeks, only odd thing was starting you had to give it two pumps with the pedal like carbs. The system, when it was on my 1.8, you never needed to touch the gas to start. Perfect O2 WB meter, fuel pressure and head temp readings. He used to have a big hill, he'd bumpstart it and it ran and started perfectly all day long. He can bump start it in the AM and it will still start 10-12 hours later. His new place doesn't have a hill. Unfortunately I'm some 1300 miles away. |
thelogo |
Mar 5 2019, 01:40 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Why are webbers so great on a /6
You dont see many for sale adds saying , (selling tripple webbers to put on f.i (IMG:style_emoticons/default/piratenanner.gif) ) But not a 4 Everyone wants f.i |
mgphoto |
Mar 5 2019, 02:02 PM
"If there is a mistake it will find me" Group: Members Posts: 1,340 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Why are webbers so great on a /6 You dont see many for sale adds saying , (selling tripple webbers to put on f.i (IMG:style_emoticons/default/piratenanner.gif) ) But not a 4 Everyone wants f.i It's the issue of originality, 914/6 had triple webers not till later were much better systems introduced for /6s. Most implants will use a tried and tested system like Motronic. Originality for the /4 is the D-Jet, one of the first mass produced FI systems used by VW, Volvo, and Jaguar. |
thelogo |
Mar 5 2019, 02:41 PM
Originality for the /4 is the D-Jet, one of the first mass produced FI systems used by VW, Volvo, and Jaguar. [/quote] May wanna add fire extinguisher ot suppression system To your budget if you go djet route (IMG:style_emoticons/default/poke.gif) Hell maybe even a fire suit |
Rand |
Mar 5 2019, 02:55 PM
Originality for the /4 is the D-Jet, one of the first mass produced FI systems used by VW, Volvo, and Jaguar. QUOTE May wanna add fire extinguisher ot suppression system To your budget if you go djet route (IMG:style_emoticons/default/poke.gif) Hell maybe even a fire suit Huh? why fire suit comment? |
Mar 5 2019, 03:03 PM
914-6 GT in waiting Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Originality for the /4 is the D-Jet, one of the first mass produced FI systems used by VW, Volvo, and Jaguar. May wanna add fire extinguisher ot suppression system To your budget if you go djet route (IMG:style_emoticons/default/poke.gif) Hell maybe even a fire suit Huh? why fire suit comment? Actually, a good running fi system doesn’t have gas vapors like carbs. There’s no reason to be afraid of FI when it has been maintained. And Rand is right. 914-4 had FI. 914-6 and early 911’s had carbs. Many people switch to something new but even more people want to run with what originally came on the engine. |
Mark Henry |
Mar 5 2019, 03:26 PM
Why are webbers so great on a /6 You dont see many for sale adds saying , (selling tripple webbers to put on f.i (IMG:style_emoticons/default/piratenanner.gif) ) But not a 4 Everyone wants f.i It's the issue of originality, 914/6 had triple webers not till later were much better systems introduced for /6s. Most implants will use a tried and tested system like Motronic. Originality for the /4 is the D-Jet, one of the first mass produced FI systems used by VW, Volvo, and Jaguar. I don't have a problem with carbs on a mechanically sound engine. Proper rebuilt/serviced IDA /6 weber's work good on a mechanically sound engine. Carbs can run good with linkage properly sorted and carb cam on T4 with a carbs on a mechanically sound engine. Notice I keep repeating some key words... (IMG:style_emoticons/default/biggrin.gif) The only wrench in Ian's area want's to put carbs on, Ian doesn't want carbs and I wouldn't recommend them for him. Carbs are off the table. |
Chris914n6 |
Mar 5 2019, 05:17 PM
I don't have a problem with carbs on a mechanically sound engine. Proper rebuilt/serviced IDA /6 weber's work good on a mechanically sound engine. Carbs can run good with linkage properly sorted and carb cam on T4 with a carbs on a mechanically sound engine. Notice I keep repeating some key words... (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/poke.gif) And I've seen more flaming carbs than leaking FI hoses... |
Chris914n6 |
Mar 5 2019, 05:21 PM
Sound's like the problem I had with the bad ignition switch. Wasn't touching the start and run contacts at the same time.
Maybe you guys could help Ian trouble shoot his Ljet and then he doesn't need an aftermarket FI system. I installed it, ran flawlessly, my 914's known good '74 Ljet system on a 2.0 914 engine. About a year or so later, just in the morning, it won't start. It cranks and cranks real good but won't catch. When I did it all new hoses including runners, cap and injector seals, head temp sensor, matching dizzy added pertronix. Like I said, worked flawlessly, I test drove it for two weeks, only odd thing was starting you had to give it two pumps with the pedal like carbs. The system, when it was on my 1.8, you never needed to touch the gas to start. Perfect O2 WB meter, fuel pressure and head temp readings. He used to have a big hill, he'd bumpstart it and it ran and started perfectly all day long. He can bump start it in the AM and it will still start 10-12 hours later. His new place doesn't have a hill. Unfortunately I'm some 1300 miles away. |
Lo-Fi Version | Time is now: 17th June 2024 - 11:34 AM |
