[quote name='Ian Stott' date='Mar 4 2019, 07:19 PM' post='2694104']
[quote name='Mark Henry' date='Mar 4 2019, 05:58 PM' post='2694077']
SDS works good on a stock 2.0 If it's fuel only I can install and tune it in one day.
Your Ljet fuel injectors aren't the best (except for Ljet), 2.0 injectors and a resistor pack (free with SDS) would be the easiest to install.
Needs a O2 WB sensor but it doesn't need a gauge, exhaust and intake bungs welded on, a small plate made to the throttle plate for the TPS and then wire it up.
I can and have done fuel only systems in one day, including tuning, but some of the wiring housekeeping might not be perfect.
I ran it on my old 1.8 DD engine for 2-3 years, except for tuning I never even had the controller on it. Way smaller tuning learning curve, dyno time not needed, perfect for old farts.
Good enough on my high buck 2.6, 180hp, nickies, T4 engine.
For your 914 I'd switch to a djet plenum, and air cleaner box, if you get me to do it I have all that ready to go, plus we could tackle the inner long stiffeners.
Since my engine was originally 2.0, D-jet don’t I have the plenum and 2.0 injectors?
We should talk or text, I should be in your phone!
