Sway bar bushing lube, glycerine paste substitute |
bbrock |
Mar 12 2019, 03:04 PM
Trying to figure out what to use to lubricate rubber sway bar bushing. The factory manual says to use "glycerine paste" but that appears to be an extinct dinosaur. I'm assuming Red Rubber Grease would be the modern choice but I would have to order it. Then my FLAPS has several brake part greases that are "safe for rubber." I already have a bottle of Permatex Ceramic Extreme Brake Parts Lubricant (pic below) for reassembling my calipers. Should be rubber safe but not sure it is right for the job. I'm just a bit confused by all the choices. Suggestions? (IMG:style_emoticons/default/confused24.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/441py33rout1ptjxn2lupv31-wpengine.netdna-ssl.com-20845-1552424651.1.jpg) |
lierofox |
Mar 12 2019, 09:57 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
My go-to for lubricating rubber parts has always been 3M silicone paste.
This may have actually been the brake parts lubricant the FLAPS was referring to since I also use it for single piston caliper slide pins. |
Lo-Fi Version | Time is now: 29th April 2024 - 10:23 PM |
