be careful with a freshly charged battery, get out the baking soda! |
dr914@autoatlanta.com |
Mar 13 2019, 09:00 AM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Moving cars around last night to make room to install a new HVAC system , I put a freshly charged battery in my 356 roadster and hit the key BAM!!!!!!!!!!!!! loud as hell, the battery exploded. Thankfully I had a bunch of baking soda handy and water to dilute and neutralize the acid or I could have had a disaster on my hands.
With all of the batteries I have installed and charged over the years this is only the second one that has exploded on me. It was late and I was in a hurry, did not ventilate the area properly, and did not have the terminals firmly connected as I was going to take the battery out right away after moving. SO a spark ignited the fumes from the freshly charged battery when I hit the key. STUPID |
Rleog |
Mar 13 2019, 09:22 AM
Senior Member Group: Members Posts: 608 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States |
Thanks for the warning. Not everyone posts their mistakes.
Blue6 |
Mar 13 2019, 09:27 AM
Senior Member Group: Members Posts: 1,035 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
Glad you were not injured, and you were able to minimize the damage. (IMG:style_emoticons/default/sad.gif)
914Sixer |
Mar 13 2019, 09:47 AM
Never can be too safe. Glad the blast was contained and no injury.
914AutoX |
Mar 13 2019, 09:59 AM
Newbie Group: Members Posts: 3 Joined: 7-January 19 From: Temecula, CA Member No.: 22,784 Region Association: Southern California |
A friend of mine was permanently blinded from a similar explosion while he was being a good Samaritan when providing a jump start. You can imagine what would have happened if the Dr. had his face above that battery when it exploded. This thread is a great reminder to always use caution around batteries, thanks for posting.
rhodyguy |
Mar 13 2019, 10:49 AM
Unplugging or turning the charger off works wonders. 30 seconds well spent.
Mar 13 2019, 11:21 AM
battery tender turned off put away, battery carried out to the car and installed with the hood up, would assume plenty of ventilation and would assume that carrying the battery at least 50 feet outside would have vented it properly! Never know
Unplugging or turning the charger off works wonders. 30 seconds well spent. |
Mar 13 2019, 11:34 AM
altitude411 |
Mar 13 2019, 11:37 AM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
Was the battery being "quick charged" or trickle charged?
Bartlett 914 |
Mar 13 2019, 11:46 AM
I would guess it was low on electrolyte leaving an excessive room for hydrogen to build up. That battery really blew up!
Spoke |
Mar 13 2019, 11:53 AM
Operating a vehicle with loose battery connections can also lead to damage to electrical components including the diodes in the alternator when a phenomenon called Load Dump happens.
Load dump is defined in ISO7637.2 as Pulse 5a. Toyota calls it "Giant Pulse" in their standards. When the engine is running and battery is disconnected or cables are loose, the inductive windings of the alternator stator react and can generate a pulse of up to 100V lasting for up to about 1/2 second. The first items to be damaged are the diodes in the alternator. Attached image(s) |
Bartlett 914 |
Mar 13 2019, 11:59 AM
Operating a vehicle with loose battery connections can also lead to damage to electrical components including the diodes in the alternator when a phenomenon called Load Dump happens. Load dump is defined in ISO7637.2 as Pulse 5a. Toyota calls it "Giant Pulse" in their standards. When the engine is running and battery disconnected, the inductive windings of the alternator stator react and can generate a pulse of up to 100V lasting for up to about 1/2 second. The first items to be damaged are the diodes in the alternator. That is pretty significant! My son worked at an oil change place that routinely would change a battery with the engine running! We both knew that was really stupid but the boss says..... I am glad he never had one blow on him. He has since moved on |
Beach914 |
Mar 13 2019, 12:42 PM
Senior Member Group: Members Posts: 966 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California |
I used to work on the golf cart fleet for a private country club in my late teens. A co-worker had the seat lid up and was spraying some terminal cleaner across the bank of the six 6V Trojan batteries when all of a sudden I see an arc across some of the terminals and the battery blew up right in his face! I thought the worse.....
Turns out His reaction time was incredible as he closed his eyes when it blew and only suffered some minor skin irritation on his forehead and his hair was singed. Be careful around batteries I learned a lesson that day. |
scott_in_nh |
Mar 13 2019, 02:44 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
I used to work on the golf cart fleet for a private country club in my late teens. A co-worker had the seat lid up and was spraying some terminal cleaner across the bank of the six 6V Trojan batteries when all of a sudden I see an arc across some of the terminals and the battery blew up right in his face! I thought the worse..... Turns out His reaction time was incredible as he closed his eyes when it blew and only suffered some minor skin irritation on his forehead and his hair was singed. Be careful around batteries I learned a lesson that day. I know a guy who did the same thing working at a lawn tractor place with my brother (back in the day) Small battery - just lost his eyebrows and had everyone in the place pissing themselves laughing at him (IMG:style_emoticons/default/av-943.gif) (that's the way it was back then) |
Retroracer |
Mar 13 2019, 03:21 PM
Senior Member Group: Members Posts: 612 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
George - glad you escaped intact! Wonder if it's still under warranty? Might be amusing to take the battery carcass and any shards of debris back to your FLAPS in a cardboard box and innocently claim it may have malfunctioned, and can I please get a replacement?
- Tony |
Coondog |
Mar 13 2019, 03:38 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Acid vapors are heavier then air so those vapors are going to set in the low spots of your engine compartment. Unless your directing a fan into that area there’s always a chance for ignition of flammable or combustible vapors.
Mar 13 2019, 03:54 PM
very good info, thank you
Operating a vehicle with loose battery connections can also lead to damage to electrical components including the diodes in the alternator when a phenomenon called Load Dump happens. Load dump is defined in ISO7637.2 as Pulse 5a. Toyota calls it "Giant Pulse" in their standards. When the engine is running and battery is disconnected or cables are loose, the inductive windings of the alternator stator react and can generate a pulse of up to 100V lasting for up to about 1/2 second. The first items to be damaged are the diodes in the alternator. |
Cairo94507 |
Mar 13 2019, 04:18 PM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Thanks for sharing that Doc. You conniver be careful enough when messing with electricity, gas, batteries, etc. You have always been candid about sharing accidents and mistakes, we all learn from that. (IMG:style_emoticons/default/beerchug.gif)
Amphicar770 |
Mar 13 2019, 08:35 PM
Senior Member Group: Members Posts: 1,191 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Wow. That is something I never heard of before yet apparently a real risk. Are AGM batteries any safer in this regard?
Mar 13 2019, 08:37 PM
Lo-Fi Version | Time is now: 17th May 2024 - 06:01 PM |
