Headlight Sealing Washer, Where to find? |
bbrock |
Mar 16 2019, 09:44 AM
rgalla9146 |
Mar 17 2019, 09:45 AM
Source ? can't say, but as I recall it's a soft foam square cross section donut. |
bbrock |
Mar 17 2019, 10:27 AM
Source ? can't say, but as I recall it's a soft foam square cross section donut. Thanks! I was wondering if it was something I could just cut out of soft foam rubber. Wonder if it is similar material to the torsion bar sealing ring. Kind of a squishy foam rubber. (IMG:style_emoticons/default/beerchug.gif) |
Mikey914 |
Mar 18 2019, 05:59 AM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Source ? can't say, but as I recall it's a soft foam square cross section donut. Thanks! I was wondering if it was something I could just cut out of soft foam rubber. Wonder if it is similar material to the torsion bar sealing ring. Kind of a squishy foam rubber. (IMG:style_emoticons/default/beerchug.gif) No it's a different material. Also the ID of that went work. I'll check with Matt but thought we had done these. Problem is getting all the new stuff listed. Mark |
bbrock |
Mar 31 2019, 12:52 PM
Mikey914 |
Mar 31 2019, 01:02 PM
Mikey914 |
Mar 31 2019, 01:17 PM
My apoplexies,
We do make these, form the drawing I thought it was under the arm mechanism at the motor under the "round flange section" section. I can now see #24 goes in 25 the metal arm. They are right here - https://900designs-container.zoeysite.com/h...aring-sleeve-1# There are 2 (technically 3) versions of the arm assemblies. @ are metal and work the same way, one integrates some of the bushings and acts as a "fuse" in case the bucket gets bound up. This might help Attached image(s) |
Mikey914 |
Mar 31 2019, 01:19 PM
The upper bushing on the new is integrated into the new arms.
Mikey914 |
Mar 31 2019, 01:21 PM
There are better pictures on the site I just don't have them on my phone.
@bbrock |
bbrock |
Mar 31 2019, 02:03 PM
@Mikey914 Thanks Mark. I don't think that's the part though. I think those bushings are 26 and 27 on the diagram. I think this one should be a foam or rubber washer intended to prevent water from migrating from the headlight compartment to frunk via the motor shaft. Could be wrong, but that's how it looks to me. Should be an easy part to source from hardware store items but figured if you guys were already making them, that would be better.
That diagram is screwy though. Ain't no hole in that cover and the actuator arm is inside, not outside. Must have been drawn during Octoberfest (IMG:style_emoticons/default/beer3.gif) |
Mikey914 |
Apr 1 2019, 11:35 AM
Ok my 1st impression was correct. I just looked more closely at the diagram and thought I misunderstood.
Since were selling a kit would be nice to have. Matt did just do this . Again I'll ask @matty900 |
Matty900 |
Apr 2 2019, 11:10 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
I believe that is a later model year part for the ones that had the boot that covers the motor/push rod. We have not made this part yet.
Mikey914 |
Apr 4 2019, 03:04 AM
I'll be checking my 75 tomorrow. may be able to mill these easily.
dr914@autoatlanta.com |
Apr 4 2019, 09:51 AM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
plenty of good used are available. We have a stock of NOS somewhere here but cannot find them right now!!!!!!
Mikey914 |
Apr 4 2019, 09:59 AM
Yeah, but why put an old crappy part on when a new one is not expensive? (IMG:style_emoticons/default/beer3.gif)
Villemi |
Jan 4 2023, 02:08 PM
Newbie Group: Members Posts: 48 Joined: 7-January 20 From: France Member No.: 23,807 Region Association: France |
Hello ,
I need this part Illustration 905-00 Item number : part #91475027710 Is it possible to find it easily please ? (IMG:http://www.914world.com/bbs2/uploads_offsite/i48.servimg.com-23807-1672862930.1.jpg)]My Webpage[/url] |
76-914 |
Jan 4 2023, 05:18 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
This came up but not a washer. https://www.ebay.com/itm/284708661929
rgalla9146 |
Jan 5 2023, 10:47 AM
This train went way off the tracks.
After checking ten headlight motors I found this one. Brent is looking for the soft round square cross section sealing washer #24 in the parts diagram. I agree it is only found on later cars that have the rubber boot on the rotating arm. See photo. (IMG:style_emoticons/default/smile.gif) Could probably be found used in usable condition. It looks like Villemi needs the same part Attached thumbnail(s) |
Mikey914 |
Jan 5 2023, 07:16 PM
I know we made these, just not sure if we got them listed. I'll have to check Monday when I get back to verify stock and get these up.
Mark |
Villemi |
Jan 7 2023, 09:16 AM
Lo-Fi Version | Time is now: 28th April 2024 - 10:21 PM |
