Pointless ignition, Brand |
cpavlenko |
Mar 18 2019, 07:52 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
What's the best brand for pointless ignition for a 009 non vacuum advance distributor. I'm hearing per-tronix r not to reliable lately . Any suggestions .
roblav1 |
Mar 18 2019, 08:29 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Distributors are "pointless" in a crank fire ignition world!
cpavlenko |
Mar 18 2019, 08:36 PM
oakdalecurtis |
Mar 18 2019, 09:12 PM
Oakdalecurtis Group: Members Posts: 1,324 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
roblav1 |
Mar 18 2019, 09:43 PM
"Distributors are "pointless" in a crank fire ignition world!"
I was just playing with words... a pointless distributor... a distributor is pointless (not needed) itself if you go crankfire. Bad humor! |
gereed75 |
Mar 19 2019, 04:27 AM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
I have the crane optical “points” and XR700 also in my six with Bosch dizzy - cured a miss and very bouncy tach that I could not fix with any amount of fiddling using conventional points.
I suspect that the timing provided by this set up is more tolerant of wear in the distributor than points. Just my theory. |
914Toy |
Mar 19 2019, 09:12 AM
Senior Member Group: Members Posts: 717 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
Make sure you connect the wiring correctly, if reversed, you will "fry" the unit - ask me how I know!
cpavlenko |
Mar 19 2019, 02:23 PM
"Distributors are "pointless" in a crank fire ignition world!" I was just playing with words... a pointless distributor... a distributor is pointless (not needed) itself if you go crankfire. Bad humor! (IMG:style_emoticons/default/laugh.gif) |
Mark Henry |
Mar 19 2019, 02:33 PM
009 isn't the best dizzy for a T4, I'd snag old mallory red cap dizzy and use a pertronix or unilight module.
With MSD you could run on a single set of points (no condenser), the points would almost last forever. |
Lo-Fi Version | Time is now: 4th May 2024 - 08:41 AM |
