battery question?, battery terminal post location? |
frankieshooz |
Mar 19 2019, 01:38 PM
Member Group: Members Posts: 83 Joined: 23-September 14 From: Mill Valley, CA Member No.: 17,945 Region Association: Northern California |
seems like a silly question but ordering a new PC925 Odyssey battery and there are two options available for positive terminal location right or left side. Does it matter or is one more advantageous than the other...seems silly as battery sits sideways and the positive cable comes from the rear....just want to be sure and order the right one in case it makes a difference
windforfun |
Mar 19 2019, 01:57 PM
Senior Member Group: Members Posts: 1,776 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Here's what I did.
Attached thumbnail(s) |
dr914@autoatlanta.com |
Mar 19 2019, 02:03 PM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
positive terminal towards the rear and toward the engine itself, do not want the terminals on the wall side just in case!!!!!
seems like a silly question but ordering a new PC925 Odyssey battery and there are two options available for positive terminal location right or left side. Does it matter or is one more advantageous than the other...seems silly as battery sits sideways and the positive cable comes from the rear....just want to be sure and order the right one in case it makes a difference |
Mar 19 2019, 02:04 PM
windforfun |
Mar 19 2019, 02:09 PM
very nice looking engine compartment by the way Here's what I did. Attached thumbnail(s) |
VaccaRabite |
Mar 21 2019, 11:10 AM
En Garde! Group: Admin Posts: 13,427 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
rhodyguy |
Mar 21 2019, 11:22 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
with a solid tray the Group 48 ( I think that's the the #) clamp will hold Optima securely. VERY. Leave the plastic covers on the side terminals.
frankieshooz |
Mar 22 2019, 12:03 AM
eyesright |
Mar 22 2019, 03:41 AM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
Yup, you want the posts inboard. Much easier to wrench the cables on and off...and much less "dangerous". With outboard posts the NEG cable is hard to get a wrench on and you are sure to make contact with the body if you should forget protocol and go for the POS terminal first. Ask for a show of hands on that one. (IMG:style_emoticons/default/headbang.gif) Outboard posts will work fine and will keep the cables out of the way, just remember protocol, and not a bad idea to keep the POS covered anyway.
Lo-Fi Version | Time is now: 29th April 2024 - 06:39 AM |
