Weber rebuild recommendations, DIY or find a Pro? Are these 44s? |
seanpaulmc |
Mar 19 2019, 07:36 PM
Member Group: Members Posts: 299 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
Hello World!
Looking for recommendations on rebuilding my Weber carburetors... Is this a DIY project for a newbie, or Are there recommended shops or vendors here for that? (updated with pictures) (2 new pics added - other side of carb) Thanks in advance, Sean |
tmessenger |
Mar 20 2019, 08:09 AM
Member Group: Members Posts: 70 Joined: 6-December 18 From: Iowa Member No.: 22,707 Region Association: Upper MidWest |
Those are vintage IDF made in Italy Webers.
If you just want to flush them out and put kits in them it's an easy project. There's a good youtube video on how to properly set the float level. If the throttle shaft bearings are bad it's more complicated and you may want to hire the rebuild out. You can check them by grabbing the linkage at each end of the throttle shafts and see if they have movement (the bearings should be tight with no up/down movement in them). If the bearings are bad there's a chance the throttle plates are also worn. Regards, Tim |
Mark Henry |
Mar 20 2019, 01:43 PM
Those are vintage IDF made in Italy Webers. If you just want to flush them out and put kits in them it's an easy project. There's a good youtube video on how to properly set the float level. If the throttle shaft bearings are bad it's more complicated and you may want to hire the rebuild out. You can check them by grabbing the linkage at each end of the throttle shafts and see if they have movement (the bearings should be tight with no up/down movement in them). If the bearings are bad there's a chance the throttle plates are also worn. Regards, Tim (IMG:style_emoticons/default/agree.gif) Look for carbon tracking on the butterflies, if it has this likely the bearings or bushings are shot. The rest is fairly easy, likely vid's on YT. |
Lo-Fi Version | Time is now: 9th May 2024 - 03:45 AM |
