FS new master cylinders 19mm $95 |
Mikey914 |
Mar 19 2019, 11:05 PM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So the majority of the master cylinders we've been selling are the easy option, so we have put the non-easy on sale. Just like stock, 19mm master cylinders. It's either this or disassemble, re-machine (for the easy kit), reassemble, and test.
Thanks to all! Mark https://900designs-container.zoeysite.com/1...er-cylinder-2-1 Attached image(s) |
db9146 |
Mar 20 2019, 08:00 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Do these come with the washers for underneath the grommets?
Any idea how these compare with the ATE brand? |
bdstone914 |
Mar 20 2019, 08:21 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Do these come with the washers for underneath the grommets? Any idea how these compare with the ATE brand? @db9146 Yes the washers are included. Compared to Ate they are functionally the same and about half the price. The Ate 17mm costs more than the 19mm. The stock 914 master was17mm. The 914-6 was 19mm. Most agree that the change from 17mm to 19mm is barely noticeable. You will have slightly reduced pedal travel and a firmer feel if you are replacing a 17mm master. Bruce |
Lo-Fi Version | Time is now: 13th May 2024 - 09:14 AM |
