Reviving NOS Webers, Initial Settings? |
bbrock |
Mar 20 2019, 08:55 PM
I didn't want to hijack the other thread but have a question about my own Webers. They are Italian 40IDFs I bought in the late 80s or early 90s. Other than finger tight bolting them on to my engine to see how cool they looked, they have never been used. No fuel has touched them. I don't remember if I even opened them to set the float levels. BUT... they were stored in a humid basement for several years before I moved to a civilized climate. So, the magnesium housing is tarnished on the outside and the plating has deteriorated on a few of the levers and such. Pretty minor stuff from what I can see.
My question: is there is anything special I should do or check other than inspecting for corroded parts and normal setup as I prep these for service? |
Superhawk996 |
Mar 22 2019, 12:34 PM
914 Guru Group: Members Posts: 5,749 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/unsure.gif)
Wow. I'm looking for the eating crow emoji. Not what I had envisioned as NOS. Were they stored outdoors? |
bbrock |
Mar 22 2019, 12:42 PM
(IMG:style_emoticons/default/unsure.gif) Wow. I'm looking for the eating crow emoji. Not what I had envisioned as NOS. Were they stored outdoors? Might as well have been. Ever spent a summer in eastern Kansas? Born and raised there but I don't recommend it. They were stored in my basement. Humidity would get so high the concrete walls and even insulated pipes would sweat. I guess these things are pretty prone to galvanic corrosion. Luckily, it looks to be just cosmetic once the residue is cleaned out. Glad to be out of that soup. |
timothy_nd28 |
Mar 22 2019, 02:33 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
(IMG:style_emoticons/default/unsure.gif) Wow. I'm looking for the eating crow emoji. Not what I had envisioned as NOS. Were they stored outdoors? Might as well have been. Ever spent a summer in eastern Kansas? Born and raised there but I don't recommend it. They were stored in my basement. Humidity would get so high the concrete walls and even insulated pipes would sweat. I guess these things are pretty prone to galvanic corrosion. Luckily, it looks to be just cosmetic once the residue is cleaned out. Glad to be out of that soup. Basement walls sweating is not a good thing at all. Is your house in a area with a high water table or is the foundation built around clay? Never mind galvanic corrosion, I'm worried about mold spores and you getting sick. Consider buying a whole house dehumidifier. They integrate with your furnace and will out perform any wheel barrel style dehumidifier. The initial cost is salty, but you can save by doing the install yourself, also happy to walk you thru the control wiring. Also consider buying a UV lamp for your HVAC equipment, its a effective way to kill any mold spores that may be already floating around. |
bbrock |
Mar 22 2019, 03:00 PM
Basement walls sweating is not a good thing at all. Is your house in a area with a high water table or is the foundation built around clay? Never mind galvanic corrosion, I'm worried about mold spores and you getting sick. Thanks for your concern but we haven't lived there for over 15 years. We were newlyweds and still in college when we bought that house. It was a really neat house out in the boonies on a lake but we were quite poor and couldn't afford AC. The basement was unfinished and a typical dank, cinder block wall storage space very common in the area. Humidity runs 80% there in the summer so even with all the windows open, and a whole house attic fan running, any air hitting those cool concrete walls quickly dropped its moisture. Still not as bad as Florida. I woke up in the Everglades once thinking it was raining before I remembered that I was INSIDE my VW bus and the rain was just dew dripping off the roof liner. We finished off the basement and added AC much later which ended the humidity problem but that was only a couple years before we moved. Now we have radon instead! |
Lo-Fi Version | Time is now: 26th April 2024 - 05:21 PM |
