Reviving NOS Webers, Initial Settings? |
bbrock |
Mar 20 2019, 08:55 PM
I didn't want to hijack the other thread but have a question about my own Webers. They are Italian 40IDFs I bought in the late 80s or early 90s. Other than finger tight bolting them on to my engine to see how cool they looked, they have never been used. No fuel has touched them. I don't remember if I even opened them to set the float levels. BUT... they were stored in a humid basement for several years before I moved to a civilized climate. So, the magnesium housing is tarnished on the outside and the plating has deteriorated on a few of the levers and such. Pretty minor stuff from what I can see.
My question: is there is anything special I should do or check other than inspecting for corroded parts and normal setup as I prep these for service? |
914werke |
Aug 19 2021, 02:23 PM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Interesting, I happen to be working on a customers 1.7L that happens to have a set of 40IDF Webers that also have this cold start mechanism,
1st for me. Besides a hole in a float, the pieces that makeup that cold start circuit were probably part of this problem, as they were a big mess. Id also be interested in the "Block off" parts & procedure as Ive got them apart for ultrasonic cleaning now. Would be nice to soda blast as the finish sure is nice but Im not set up for that..yet (IMG:style_emoticons/default/smile.gif) Edit: I followed the link to TheSamba thread. Looks like all I need is some brass rod & some calipers |
IronHillRestorations |
Aug 20 2021, 04:47 AM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Interesting, I happen to be working on a customers 1.7L that happens to have a set of 40IDF Webers that also have this cold start mechanism, 1st for me. Besides a hole in a float, the pieces that makeup that cold start circuit were probably part of this problem, as they were a big mess. Id also be interested in the "Block off" parts & procedure as Ive got them apart for ultrasonic cleaning now. Would be nice to soda blast as the finish sure is nice but Im not set up for that..yet (IMG:style_emoticons/default/smile.gif) Edit: I followed the link to TheSamba thread. Looks like all I need is some brass rod & some calipers Weber enrichment disable I chucked the tap in a drill press (turned by hand) to tap the bores |
Lo-Fi Version | Time is now: 28th April 2024 - 12:11 AM |
