LED Failure Revisited, Oddesy Continues LOL |
914Sixer |
Mar 21 2019, 08:05 AM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
The journey continues with the purchase of the new 4 element bulbs for the truck. Got the new set of lights installed. One fog light bulb DOA. Contacted seller and got a new one on the way. Bulb arrived yesterday, plugged it in DOA. (IMG:style_emoticons/default/lol-2.gif) Contacted seller again, two new ones on the way this time. High failure rate must be acceptable to quality control.
Attached image(s) |
Spoke |
Mar 21 2019, 12:13 PM
Jerry Group: Members Posts: 6,984 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Bummer. They never lit up or lit up then quickly died?
ssuperflyoldguy |
Mar 21 2019, 02:51 PM
Member Group: Members Posts: 173 Joined: 15-November 15 From: NorCal - East Bay Baby! Member No.: 19,364 Region Association: None |
914Sixer |
Mar 21 2019, 03:32 PM
Never lit up. I tested the socket with old school bulb and a 2 element LED and both worked.
Superhawk996 |
Mar 21 2019, 05:00 PM
914 Guru Group: Members Posts: 5,845 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Just a thought. (IMG:style_emoticons/default/idea.gif)
LED's are a Light Emitting Diode. Diodes only conduct in one direction. LED's only conduct with proper polarity applied. Take one of the DOA ones and reverse polarity and see if it works. China quality control being what it is, they may have the terminal connections within the LED reversed. Long shot but what do you have to loose? Now if it works you still have a problem because I'd never suggest reversing polarity on the vehicle. More of a science experiment. |
rhodyguy |
Mar 21 2019, 05:05 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Seems like a lot of work for some lumens.
914Sixer |
Mar 22 2019, 05:44 AM
Plugs on the LED's are directional and only go one way. But that does not mean they were not wired backwards. I will give it a test later today.
Lo-Fi Version | Time is now: 22nd May 2024 - 01:01 AM |
