Fuel Pump Iffy, No purring |
Chip |
Mar 21 2019, 06:07 PM
Member Group: Members Posts: 125 Joined: 1-April 17 From: Brigham City, UT Member No.: 20,986 Region Association: Intermountain Region |
First Start :
Fuel pump not working when ignition turned on. Fuel pump works when connected to an independent battery. Wiring to pump is ok. Questions: Shouldn't pump come on with ignition? Shouldn't pump stay on while vehicle running? Could it be s relay? Where is the "Main Relay." Other possibilities..., Thank you. (IMG:style_emoticons/default/wacko.gif) |
Dave_Darling |
Mar 21 2019, 10:43 PM
What fuel system is on the car? Carbs, 1.7/2.0 D-jetronic, 1.8 L-jetronic (not available originally in a 73), or something else?
--DD |
Chip |
Mar 22 2019, 01:34 AM
What fuel system is on the car? Carbs, 1.7/2.0 D-jetronic, 1.8 L-jetronic (not available originally in a 73), or something else? --DD It's a D-jetronic system, 1.7. Fuel pump is not working when ignition is turned on. Pump works (hums) when attached directly to independent battery. Pump moved to front. Perhaps a relay? Where? Fuses ok. Wiring seems to be ok. Any help is greatly appreciated. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:54 PM |
