Terry Cable Clutch Cable Disaster |
yeahmag |
Mar 24 2019, 09:10 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Has anyone other than me had bad luck with Terry Cables? The one I installed stretched constantly, felt "spongy", and had what I can only describe as "high friction". I put in a cheap Cofle clutch cable and it feels like a million bucks.
-Aaron |
mark04usa |
Mar 24 2019, 10:35 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
I noticed the same problem with a Terry cable...so much friction within that heavy cable, I didn't run with it very long.
jim_hoyland |
Mar 25 2019, 05:49 AM
Get that VIN ? Group: Members Posts: 9,271 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I noticed the same problem with a Terry cable...so much friction within that heavy cable, I didn't run with it very long. (IMG:style_emoticons/default/agree.gif) Not reliable at all. Is there a 914Rubber replacement yet ? (IMG:style_emoticons/default/smile.gif) |
wndsrfr |
Mar 25 2019, 05:56 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Genuine Porsche...really better construction and feel..get it from your dealer....
bdstone914 |
Mar 25 2019, 06:09 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I noticed the same problem with a Terry cable...so much friction within that heavy cable, I didn't run with it very long. (IMG:style_emoticons/default/agree.gif) Not reliable at all. Is there a 914Rubber replacement yet ? (IMG:style_emoticons/default/smile.gif) @mikey914 |
bdstone914 |
Mar 25 2019, 06:53 AM
Has anyone other than me had bad luck with Terry Cables? The one I installed stretched constantly, felt "spongy", and had what I can only describe as "high friction". I put in a cheap Cofle clutch cable and it feels like a million bucks. -Aaron Aaron, I would give them a call at 800.854.4691 and report the problem. Anyone have experience with the accelerator cable? I heard they use less but larger diameter strands. I have one of their clutch cables i was going to use but am going to hold off on that. @914sixer @yeahmag @mikey914 |
76-914 |
Mar 25 2019, 08:24 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Mikey914 |
Mar 25 2019, 08:43 AM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This is what I'm running into on our version. The issue is a matter of clearances can the way they join the sheath together. I think I have a solution that I will be trying this week. If it works and I can get some testing in on it I'll be able to begin production.
Mark |
mgphoto |
Mar 25 2019, 06:28 PM
"If there is a mistake it will find me" Group: Members Posts: 1,338 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Has anyone other than me had bad luck with Terry Cables? The one I installed stretched constantly, felt "spongy", and had what I can only describe as "high friction". I put in a cheap Cofle clutch cable and it feels like a million bucks. -Aaron Aaron, I would give them a call at 800.854.4691 and report the problem. Anyone have experience with the accelerator cable? I heard they use less but larger diameter strands. I have one of their clutch cables i was going to use but am going to hold off on that. @914sixer @yeahmag @mikey914 Haven’t figured the reply thing? I’ve been using the accelerator cable from Terry for about a year, the cable is similar to the clutch cable multiple strands braided together. I’ve never had that kind of problem with a Terry cable, I would check the tunnel guide tube welds and check for interference between the clutch release fork and the transmission case. Often times when the flywheel is resurfaced and the corresponding amount of material is not used under the clutch fork pivot ball, that causes the fork/case interference. An additional washer under the ball usually does the trick but you have to use sealant on the threads and washers. |
Lo-Fi Version | Time is now: 4th May 2024 - 06:08 PM |
