-6 originality question, Front shock tar. Some with and some not? |
mountainroads |
Mar 29 2019, 11:26 AM
Member Group: Members Posts: 210 Joined: 19-February 12 From: Seattle Member No.: 14,145 Region Association: Pacific Northwest |
A local shop is busy fixing some of the "work" that another local shop performed. I'm not happy about having to do that. PM me for details, if you want more info.
Although no concours or originality queen, I asked the shop owner if he could smear some of that undercoating/tar around the front shock towers while the car was in his shop, since that is supposed to be one of the defining characteristics of a -6. He said no problem, he'd look into it. He called back the other day and said: "I looked at my car and it doesn't have what you describe. Happy to do it, but are you sure and can you send me a pic?" I asked if he was certain the stuff hadn't been removed at some point and he said he was positive. I've seen his car. It's a 40K mile, original paint, unmolested survivor. I have no reason to doubt either his expertise or knowledge of the car's history. So..., is it possible that some sixes left the factory without that stuff? Yes, I already looked in the -6 originality and front trunk threads here and couldn't find a picture or definitive answer. Input on subject and if someone could post a pic, it would greatly appreciated. Also, cad or zinc-plated mounting hardware? TIA. - MR |
mountainroads |
Mar 29 2019, 09:41 PM
Gents: Thank you very much for the corroborating info and the pics. Much appreciated!
- MR |
sixnotfour |
Mar 30 2019, 11:43 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Gents: Thank you very much for the corroborating info and the pics. Much appreciated! - MR Have him take a pic of his -6 , for reference..no goo @mountainroads |
mountainroads |
Apr 5 2019, 10:51 AM
Gents: Thank you very much for the corroborating info and the pics. Much appreciated! - MR Have him take a pic of his -6 , for reference..no goo @mountainroads An update: Was at the shop the other day checking progress and talked to the owner's son. Turns out Dad's car is not quite as original as I thought. Low mileage and definitely stock, but son told me Dad's car had in fact been repainted. That said, he was pretty sure that only the outside was repainted and neither trunk had been touched. Which, still leaves the question of why no tar. Dad's pretty much retired and only comes in occasionally to cover, so getting a pic will be tough. I'll ask if one of them would be kind enough to take one for possible reference, although at this point I'm going to assume that tar was removed instead of being a unicorn. - MR |
davep |
Apr 8 2019, 08:16 AM
914 Historian Group: Benefactors Posts: 5,144 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
An update: Was at the shop the other day checking progress and talked to the owner's son. Turns out Dad's car is not quite as original as I thought. Low mileage and definitely stock, but son told me Dad's car had in fact been repainted. That said, he was pretty sure that only the outside was repainted and neither trunk had been touched. Which, still leaves the question of why no tar. Check the area where the VIN is stamped on the inner fender. If the VIN is painted over in body color then it has been repainted. Original finish appears to have the VIN taped over before painting, then the tape removed to leave a rectangular area in grey. Since this area does not rust quickly there may be a clear coating over the VIN stamping. In general, the body color inside the trunk is not of the same quality as on the outer surfaces. |
Lo-Fi Version | Time is now: 21st May 2024 - 12:50 PM |
