FS: 1973 914 D-Jet complete FI system-all hardware, Great MPS, and other sensors included, but missing AAR |
jjs3rd914 |
Mar 30 2019, 12:22 PM
Member Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 |
For sale a complete D-Jet system from a 914 GA engine less the aux air regulator (AAR).
Asking $595 (plus applicable shipping) or best reasonable offer. Really want to sell as one system, but if no reasonable offer received will piece out. The MPS is worth several hundred dollars alone. This 73 system is to be used with the 270 ohm resistor in line with cylinder head temp sensor (supplied). Please ref photos as included MPS 022-906-051C TESTED and in 5 minutes has little leakage from a set vacuum of 15" to just above 14". Very acceptable Complete distributor 039-905-205 with the trigger point installed and working vacuum advance - but entire unit not tested Throttle body 039-133-067 not tested 7 green injectors 039-906-031 not tested ECU 022-906-021E Bosch 0-280-000-037 with attached harness and mounting bracket. Harness sheaving is hardened in most places, some connectors should be re-soldered, but otherwise intact and rebuildable and usable. Not tested Cleaned and freshly painted air box with the cold start valve 311-906-171B, air intake temp sensor 311-906-081A, and thermo switch 311-906-161C. None tested Ballast resistor 039-971-762A appears to be open, so included is a 270 ohm radio shack resistor 3 port fuel pump not trested Decel valve 039-133-551 not tested Fuel pressure regulator Bosch 0-280-160-001 not tested Air intake tubes freshly painted Air cleaner housing 2 parts freshly cleaned and painted Left and right fuel rails Note: no gaskets, hoses, seals, o-rings, air cleaner element, etc, or other hardware included. System sold as is, no warranty offered or implied, no returns, what you see is what you get. Am cleaning house. Thanks jjs3rd914 |
jjs3rd914 |
Mar 30 2019, 02:38 PM
I did not state it but system is from a 2 liter GA engine. Not from a 1.7L
Thanks jjs3rd914 |
Sea Rooster |
Mar 30 2019, 02:56 PM
Member Group: Members Posts: 106 Joined: 8-March 18 From: Nashville, TN Member No.: 21,948 Region Association: South East States |
If you decide to part out I'd like the distributor and fuel rails.
sithot |
Mar 30 2019, 05:42 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
PM-Email sent
jjs3rd914 |
Mar 31 2019, 09:35 AM
If you decide to part out I'd like the distributor and fuel rails. I do have another set of fuel rails but not another dizzy. Will sell the fuel rails for $10 for the both. The metal sealing washer is missing but included a couple of orings that might work. Shipping will be extra in a USPS small flat rate box for $7.50. PM me if interested. I also sent you a PM with same message. Thanks jjs3rd914 |
jjs3rd914 |
Apr 1 2019, 11:05 AM
RFoulds |
Apr 2 2019, 01:23 PM
Green Teen 66 Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
great deal. if you part it out, I need ECU.
jjs3rd914 |
Apr 7 2019, 06:19 PM
All parts sold as system.
Thanks |
OG2.0P914 |
Aug 9 2020, 12:52 PM
I'm new here ... Group: Members Posts: 0 Joined: 30-April 19 From: Los Angeles Member No.: 23,076 Region Association: Southern California |
Lo-Fi Version | Time is now: 18th May 2024 - 01:13 PM |
