Question for those of you without heat |
Bulldozer27 |
Apr 8 2019, 07:12 PM
Newbie Group: Members Posts: 48 Joined: 14-November 18 From: Sandy Eggo, CA Member No.: 22,653 Region Association: Southern California |
What do you use to cap the holes in the rear of the longs where the heat exchanger hoses are normally attached?
bbrock |
Apr 8 2019, 07:17 PM
Spray paint caps fit perfectly. I used them to keep media out while blasting the car.
Apr 8 2019, 07:44 PM
914Toy |
Apr 8 2019, 08:13 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
2” black plastic pipe caps fit perfectly - use some glue to secure them.
BPic |
Apr 9 2019, 03:58 AM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
I deleted my heat as well and went a different route. I wanted something a little more permanent but had to be removeable if needed so I found these SS caps that the beer brewers use on their equipment. I drilled a hole in the center and used a SS Allen head bolt. I took a 2.5" piece of steel about a half inch wide and welded a nut to it. The steel fits across the hole, inside, and the bolt snugs it nice and tight. I brushed on seam sealer as a "gasket" and then brushed on seam sealer like the factory and partially covered the cap. Looks pretty clean and it will be painted the same color as the car. I can't find any installed pics but will look again. Here is what I bought, and almost a perfect fit. The groove on the back fits on the lip of the holes.
Mark Henry |
Apr 9 2019, 05:57 AM
Cut off bottom of a pop can and a thin bead of RTV, I use them for big and small holes just cut to size. Only meant to be temporary, but a preheater hole on my T1 engine has one that must be 25 years old now.
I also use paint can lids where they fit. |
bbrock |
Apr 9 2019, 07:31 AM
I deleted my heat as well and went a different route. I wanted something a little more permanent but had to be removeable if needed so I found these SS caps that the beer brewers use on their equipment. I drilled a hole in the center and used a SS Allen head bolt. I took a 2.5" piece of steel about a half inch wide and welded a nut to it. The steel fits across the hole, inside, and the bolt snugs it nice and tight. I brushed on seam sealer as a "gasket" and then brushed on seam sealer like the factory and partially covered the cap. Looks pretty clean and it will be painted the same color as the car. I can't find any installed pics but will look again. Here is what I bought, and almost a perfect fit. The groove on the back fits on the lip of the holes. @BPic and you call me "Mr. OCD"? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) |
BPic |
Apr 9 2019, 11:16 AM
I deleted my heat as well and went a different route. I wanted something a little more permanent but had to be removeable if needed so I found these SS caps that the beer brewers use on their equipment. I drilled a hole in the center and used a SS Allen head bolt. I took a 2.5" piece of steel about a half inch wide and welded a nut to it. The steel fits across the hole, inside, and the bolt snugs it nice and tight. I brushed on seam sealer as a "gasket" and then brushed on seam sealer like the factory and partially covered the cap. Looks pretty clean and it will be painted the same color as the car. I can't find any installed pics but will look again. Here is what I bought, and almost a perfect fit. The groove on the back fits on the lip of the holes. @BPic and you call me "Mr. OCD"? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/happy11.gif) |
dr914@autoatlanta.com |
Apr 9 2019, 01:04 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
CoronaMike |
Apr 9 2019, 03:33 PM
Member Group: Members Posts: 152 Joined: 11-February 19 From: Maryville, TN Member No.: 22,868 Region Association: South East States |
I don't think my holes are capped.... what's the down side?
BPic |
Apr 9 2019, 04:18 PM
I don't think my holes are capped.... what's the down side? You don't want critters and funk in your hole(s) (IMG:style_emoticons/default/lol-2.gif) |
worn |
Apr 9 2019, 07:47 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
jmitro |
Apr 9 2019, 09:04 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
bdstone914 |
Apr 11 2019, 11:03 AM
I don't think my holes are capped.... what's the down side? @CoronaMike Dead rodents and nests in the longs. Ask Jamie Rust. (IMG:style_emoticons/default/w00t.gif) |
Bulldozer27 |
Apr 11 2019, 07:37 PM
tomeric914 |
Apr 12 2019, 07:28 AM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Cut off bottom of a pop can and a thin bead of RTV, You mean a soda can? (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/stirthepot.gif) |
Mark Henry |
Apr 12 2019, 07:34 AM
Cut off bottom of a pop can and a thin bead of RTV, You mean a soda can? (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/stirthepot.gif) Yes...and it's not a beanie it's called a toque (IMG:style_emoticons/default/dry.gif) Hosers! Take off, eh? (IMG:style_emoticons/default/rolleyes.gif) |
mlindner |
Apr 12 2019, 03:13 PM
Senior Member Group: Members Posts: 1,521 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Sorry off topic, have any of you converted your seats to electric...Mark
Lo-Fi Version | Time is now: 17th May 2024 - 03:08 PM |
