Bulldozer27
Apr 8 2019, 07:12 PM
What do you use to cap the holes in the rear of the longs where the heat exchanger hoses are normally attached?
bbrock
Apr 8 2019, 07:17 PM
Spray paint caps fit perfectly. I used them to keep media out while blasting the car.
Apr 8 2019, 07:44 PM
QUOTE(bbrock @ Apr 8 2019, 09:17 PM)
Yup. Secure with a hose clamp and it almost looks stock.
914Toy
Apr 8 2019, 08:13 PM
2” black plastic pipe caps fit perfectly - use some glue to secure them.
BPic
Apr 9 2019, 03:58 AM
I deleted my heat as well and went a different route. I wanted something a little more permanent but had to be removeable if needed so I found these SS caps that the beer brewers use on their equipment. I drilled a hole in the center and used a SS Allen head bolt. I took a 2.5" piece of steel about a half inch wide and welded a nut to it. The steel fits across the hole, inside, and the bolt snugs it nice and tight. I brushed on seam sealer as a "gasket" and then brushed on seam sealer like the factory and partially covered the cap. Looks pretty clean and it will be painted the same color as the car. I can't find any installed pics but will look again. Here is what I bought, and almost a perfect fit. The groove on the back fits on the lip of the holes.
Click to view attachmentClick to view attachment
Mark Henry
Apr 9 2019, 05:57 AM
Cut off bottom of a pop can and a thin bead of RTV, I use them for big and small holes just cut to size. Only meant to be temporary, but a preheater hole on my T1 engine has one that must be 25 years old now.
I also use paint can lids where they fit.
bbrock
Apr 9 2019, 07:31 AM
QUOTE(BPic @ Apr 9 2019, 03:58 AM)
Click to view attachment @BPic and you call me "Mr. OCD"?
BPic
Apr 9 2019, 11:16 AM
QUOTE(bbrock @ Apr 9 2019, 09:31 AM)
dr914@autoatlanta.com
Apr 9 2019, 01:04 PM
yup
QUOTE(bbrock @ Apr 8 2019, 06:17 PM)
CoronaMike
Apr 9 2019, 03:33 PM
I don't think my holes are capped.... what's the down side?
BPic
Apr 9 2019, 04:18 PM
QUOTE(CoronaMike @ Apr 9 2019, 05:33 PM)
You don't want critters and funk in your hole(s)
worn
Apr 9 2019, 07:47 PM
QUOTE(dr914@autoatlanta.com @ Apr 9 2019, 11:04 AM)
yup
Pop cans.
jmitro
Apr 9 2019, 09:04 PM
bdstone914
Apr 11 2019, 11:03 AM
QUOTE(CoronaMike @ Apr 9 2019, 02:33 PM)
@CoronaMike Dead rodents and nests in the longs. Ask Jamie Rust.
Bulldozer27
Apr 11 2019, 07:37 PM
QUOTE(jmitro @ Apr 9 2019, 08:04 PM)
+100, thanks for this recommendation
tomeric914
Apr 12 2019, 07:28 AM
QUOTE(Mark Henry @ Apr 9 2019, 06:57 AM)
You mean a soda can?
Mark Henry
Apr 12 2019, 07:34 AM
QUOTE(tomeric914 @ Apr 12 2019, 09:28 AM)
Yes...and it's not a beanie it's called a toque
Hosers! Take off, eh?
mlindner
Apr 12 2019, 03:13 PM
Sorry off topic, have any of you converted your seats to electric...Mark
