tires, oooohhhhh sh*t!!!!!! |
firstknight13 |
Jun 23 2005, 08:34 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
well i thought i was having a great day. the tire guy called and said my falken azien 615 rt 205/50/15 were in and come on down. well i had brand new empi 8 spoke repros for 6 months and couldn't wait to have them installed. went down paid $430.00 tx included mounted , balanced, alainged. they looked sweet on the car on the lift. so the tech says they have to drive the car off the lift and into the next bay... ok... he backs it up and 10 feet back he shuts it off and shakes his head.??? oh no what ??? the frigin rear wheels rub in the fender well. front is mint!!! what to do???call my new best teener friend and ask him!! chris says empi has wider offset!!! only thing i could do is put the new tires on the malhe's. tires are great!!! hug the road like glue!!! any sugestions??? i love the 8 spokes!!! cant roll the fender as i have new paint... thanks (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Jun 23 2005, 08:53 PM
well, how much do they rub? the inner lip can be rolled without destroying the paint, if you're careful.
but if you need more clearance than that, you'll need to pull the fenders ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy |
xsboost90 |
Jun 23 2005, 09:14 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
bah! just pull some camber plates!
Jun 23 2005, 09:17 PM
that might help 'ya too. again, if it's just rubbing a bit, adding some neg. camber (removing shims) might just do the trick ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy |
rhodyguy |
Jun 23 2005, 10:07 PM
why roll the fenders, do thousands of $ worth of body damage, for $130 worth of wheels? (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) pop for some panasports. same look, nice fit. why fuck up the rear alignment for $130...
k |
Aaron Cox |
Jun 23 2005, 10:09 PM
im with kev on this....
get real offset wheels... or have the tire monkeys pull some shims... im runnin almost -2 deg of rear camber LOL and 8" wheels soon to be in the rear (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
firstknight13 |
Jun 24 2005, 10:33 AM
if you pull off camber plates how much can you gain i need almost a finger width to clear??? what about lifting the rear??? and with what would you do it with?? thanks again you pros!!! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
TravisNeff |
Jun 24 2005, 10:47 AM
I am not sure how much you can gain by pulling shims, up to about -3 degrees? the downside is that you will wear through tires quickly on the inside edge. Any way you look at it, you are going to have to make some compromises, wheels, alignment or working over the fenders.
rhodyguy |
Jun 24 2005, 11:00 AM
i think camp914 has a set of panasports that might be for sale (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) . you're going to go through $400+- worth of new tires in no time. you need to cut your loses. get proper wheels. i'll shut up now.
k |
TonyAKAVW |
Jun 24 2005, 12:31 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I run the empi 8 spoke wheels on my car with 195/50 tires and have no rubbing issues. I don't know if they make the Azenis in that size...
(I have stock, un rolled fenders) -Tony |
TravisNeff |
Jun 24 2005, 12:34 PM
I had the 8 spoke empi wheels and 205x50 tires, had to do some work on the fenders to get those to fit as well.
Mueller |
Jun 24 2005, 12:37 PM
there should be a law against selling those POS vw bug rims to be used on 914's......same bolt-pattern, just a screwy offset for wider tires........I guess it was okay 20 years ago when everyone ran skinny little tires.....
only real option is get "real" rims, Fuchs, Mahles, Pedrinis, Panasports or Revolution (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) or get a different size tire........ |
rhodyguy |
Jun 24 2005, 12:52 PM
once new tires are mounted they become USED TIRES. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) esp if they've rubbed on the fender wells. bummer. until you decide what to do just source some steel wheels and clean them up. cheap and you can run the wide tires.
k |
jr91472 |
Jun 24 2005, 01:18 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Seems like everyone's car is a little different. I could only get 185s on my empi's. Also the primary reason I swapped them for 4 bolt fuchs.
good luck (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
firstknight13 |
Jun 26 2005, 01:35 PM
i guess i'l just have to buy another set of tires and run 195's on the empis and keep the 205's on the mahle's (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) hey it's only money and us PORSCHE guys have plenty of it (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Joe Ricard |
Jun 26 2005, 05:21 PM
Azienis are fatter than your average 205/50-15. Just like Hoosier is is WAY fatter than even the Kumhos.
That's one reason the STS crowd is so nuts over the falken tires. Funny when I bought the yellow car it had 205/60-15 on EMPI rims the lips were rolled in back and had lots of clearance well I could get my pinky inbetween. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) the 205/50-15 Kumhos rubb the inner fender well without 1/4" spacer on Fuchs. GO figure. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) Hoosiers just rub everywhere. Unless (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) got about 10,000 more whacks to go to make the fenders clear GUD and look Better. (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 02:06 PM |
