Tire Diameter, Front Tire Choise |
mzapisek |
Apr 10 2019, 08:00 AM
Member Group: Members Posts: 91 Joined: 10-June 04 From: Syracuse, NY Member No.: 2,188 Region Association: North East States |
I'm running 245/50/16 on the back and 225/55/16 fronts with GT steel flares. Tires look good and perform well. I do get rubbing on the inner fender well at full lock. I am using a 1/2" spacer in the front.
I have a spare set of 16" front wheels. If I go with 205/55/16 to reduce the section width the tire diameter reduces by almost one inch to 24.9". My current set up has almost identical tire diameters at 25.7". Is there a problem with running smaller diameter tires in the front? Handling? Alignment? Would this create to much rake? Appreciate some input. I searched but couldn't find a definitive answer. Thanks. |
larryM |
Apr 16 2019, 10:46 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
you don't tell us what ET or backspace your wheels are - or what brand
- nobody can give you a credible tire recommend without that info check fitments yourself here http://www.rimsntires.com/specspro.jsp |
Lo-Fi Version | Time is now: 17th May 2024 - 06:48 PM |
