Tire Diameter, Front Tire Choise |
mzapisek |
Apr 10 2019, 08:00 AM
Member Group: Members Posts: 91 Joined: 10-June 04 From: Syracuse, NY Member No.: 2,188 Region Association: North East States |
I'm running 245/50/16 on the back and 225/55/16 fronts with GT steel flares. Tires look good and perform well. I do get rubbing on the inner fender well at full lock. I am using a 1/2" spacer in the front.
I have a spare set of 16" front wheels. If I go with 205/55/16 to reduce the section width the tire diameter reduces by almost one inch to 24.9". My current set up has almost identical tire diameters at 25.7". Is there a problem with running smaller diameter tires in the front? Handling? Alignment? Would this create to much rake? Appreciate some input. I searched but couldn't find a definitive answer. Thanks. |
mzapisek |
Apr 18 2019, 08:39 AM
Wheels are Fuchs standard 911 offset. Went with the 205's up front. Much lighter steering feel and eliminated the rubbing. Very happy. Thanks for the input.
Lo-Fi Version | Time is now: 17th May 2024 - 08:49 PM |
