> Something Evil Part II, Starting Over
Mblizzard
post Apr 17 2019, 08:17 AM
Well I have been delayed with life and too many things going on. But after purchasing a lot of parts, it is time to start the process.
Up front big thanks to Charles and Nicole at the Type 4 Store for putting up with so many questions. Thanks to Len Hoffman for waiting on me for so long on the heads. Also to Jake Raby for his Type 4 build CD and while not giving build advice but pointing me in the right direction on a number of issues. I am afraid to look at all of the other vendor receipts as I might start to add it all up $$$$ but I will compile a list of all the vendors and add photos.
So the basics. Going for a 2.6 L FI with Microsquirt. Looking to hit 9.5:1 compression.
102 mm Nickies with Custom 102mm Dished JE Pistons for 78mm stroke and 22mm pins.
78 mm crank - New this time!
H-beam Rods 5.325 with Type 1 Rod Journals
LE-200 heads - Valve sizes: 44mm x 38mm by Manley, intake ports flow 200CFM @ .500” valve lift, and ceramic coated. 911 swivel foot valve adjusters
SPEC Clutch Kit - Stage 1 Lightened flywheel
Type 4 Store Cam Part# 9500 with Parkerized Lifters and Modified Cam Gear,
chromoly pushrods
Intake
Valve Lift: .500
Duration: 284
Duration@ .050": 250
Exhaust
Valve Lift: .500
Duration: 300
Duration@ .050": 270
Mahle bearings throughout
315cc/min Fuel Injector: Bosch 0280150945
48 mm CB Performance intakes. Dual throttle bodies with CSP linkage
Modified 30mm Oil Pump
Racewear Case thru-Stud Kit and Head Stud Kit
Tangerine Racing Remote Oil Cooler Kit
Planning on Tangerine Racing 1 1/2" Street System: - High Temp coated header with EVO II Silencer
Case and all the parts are going to shop Friday for opening up to fit the 102s and balancing of all parts.
Goal is to be done by Okteenerfest!
May have potential to be evil?
Thoughts suggestions?
Mblizzard
post Aug 6 2019, 03:00 PM
Went through the mock up process all things seem to rotate and be clear. I felt I had a couple of points on the crank to case clearance that were a bit tight so I took a bit more off the case to provide clearance.
Checked deck height at 0.43 mm which with the 1 mm step the wise Len Hoffman machined into my heads will give me about a 9.5:1 compression ratio.
The heads will be here Wednesday! (IMG:style_emoticons/default/piratenanner.gif)
Taking everything back apart for final inspection and cleaning for final assembly.
Of course I forgot that the gasket set does not come with the windage tray seal so I had to order one. I heard of people leaving them out completely any thoughts on that?
Should start final assembly this weekend!
Mblizzard   Something Evil Part II   Apr 17 2019, 08:17 AM
thelogo   Not trying to drudge up old memories but im trying...   Apr 17 2019, 08:27 AM
Mblizzard   Not trying to drudge up old memories but im tryin...   Apr 17 2019, 10:15 AM
JOEPROPER   Not trying to drudge up old memories but im tryi...   Apr 17 2019, 10:23 AM
Mblizzard   [quote name='Mblizzard' post='2706174' date='Apr ...   Apr 17 2019, 10:32 AM
Chi-town   You forgot what you're controlling this with, ...   Apr 17 2019, 09:29 AM
Mblizzard   You forgot what you're controlling this with,...   Apr 17 2019, 09:57 AM
VaccaRabite   What happened with your 2056? Zach   Apr 17 2019, 10:10 AM
Mblizzard   What happened with your 2056? Zach Sent to Ger...   Apr 17 2019, 10:16 AM
Bills914-4   Hi Mike, Welcome to the big motors >:D , Nice ...   Apr 17 2019, 03:49 PM
Mblizzard   Hi Mike, Welcome to the big motors >:D , Nice...   Apr 17 2019, 07:04 PM
Bills914-4   Hi Mike, Welcome to the big motors >:D , Nic...   Apr 19 2019, 05:06 PM
Mblizzard   [quote name='Mblizzard' post='2706305' date='Apr ...   Apr 19 2019, 06:18 PM
Mblizzard   [quote name='Mblizzard' post='2706305' date='Apr ...   Apr 22 2019, 10:46 AM
jd74914   Contacted Calico but nothing yet. If you're ...   Apr 22 2019, 11:40 AM
Mblizzard   Bill, On the Timesert install, I have the RaceWar...   May 1 2019, 07:57 AM
Bills914-4   Bill, On the Timesert install, I have the RaceWa...   May 1 2019, 08:49 AM
Mblizzard   [quote name='Mblizzard' post='2710199' date='May ...   May 1 2019, 09:19 AM
mb911   Gonna be a monster motor.. I would love to develop...   Apr 17 2019, 04:46 PM
Mark Henry   Basically you will have the same engine I have in ...   Apr 17 2019, 08:00 PM
Mblizzard   Basically you will have the same engine I have in...   Apr 18 2019, 05:59 AM
Mblizzard   Basically you will have the same engine I have in...   Apr 18 2019, 09:06 AM
914dave   Mike Are you going with the one piece crankshaft d...   Apr 18 2019, 06:05 AM
Mblizzard   Mike Are you going with the one piece crankshaft ...   Apr 18 2019, 07:09 AM
thelogo   I am sure it would not turn so they opened it up...   Apr 18 2019, 07:21 AM
Mblizzard   I am sure it would not turn so they opened it ...   Apr 18 2019, 08:01 AM
bahnzai   +1 on Calico Coatings! Did this on a 3.5 930 e...   Apr 20 2019, 03:30 AM
RFoulds   you mentioned some of your old components for sale...   Apr 22 2019, 03:10 PM
Mblizzard   you mentioned some of your old components for sal...   Apr 22 2019, 05:31 PM
RFoulds   Sent you a PM   Apr 23 2019, 09:00 AM
Mblizzard   Not much progress. Still waiting on machine shop....   Apr 29 2019, 07:35 AM
Mblizzard   Well more good news! Shop called and they wil...   Apr 30 2019, 11:47 AM
Mblizzard   Well still waiting on the machine shop. Making so...   May 13 2019, 08:45 AM
Mblizzard   double   May 13 2019, 12:47 PM
Mblizzard   Well finally got my case back from shop. Have so...   Jun 20 2019, 06:57 PM
Mark Henry   Well finally got my case back from shop. Have s...   Jun 21 2019, 07:43 PM
Mblizzard   Well finally got my case back from shop. Have ...   Jun 24 2019, 08:08 AM
914werke   :drooley:   Jun 20 2019, 08:54 PM
DRPHIL914   :Qarl: awesome! looking good, you've go ...   Jun 21 2019, 07:46 AM
Betty   GO MIKE, GO MIKE, GO MIKE!!! You can ...   Jun 21 2019, 07:23 PM
Mblizzard   Finally back in the country! Now for building...   Jul 23 2019, 08:58 AM
Mblizzard   Was making progress! Got the gears on the cra...   Jul 25 2019, 08:20 AM
Mblizzard   Well not a lot of progress as of late. Still sorti...   Aug 1 2019, 06:58 AM
Betty   Well not a lot of progress as of late. Still sort...   Aug 1 2019, 11:39 AM
Mblizzard   Moving forward. Man Nickies are beautiful. ...   Aug 3 2019, 08:05 PM
malcolm2   Moving forward. Man Nickies are beautiful. Cla...   Aug 15 2019, 10:25 AM
Mblizzard   Went through the mock up process all things seem t...   Aug 6 2019, 03:00 PM
ClayPerrine   Went through the mock up process all things seem ...   Aug 6 2019, 08:53 PM
Mblizzard   Went through the mock up process all things seem...   Aug 7 2019, 04:16 AM
Betty   :cheer: :sawzall: :cheer: :smash: :cheer: :we...   Aug 6 2019, 08:43 PM
Mblizzard   Got a nice little package from Mr. Hoffman today...   Aug 9 2019, 11:55 AM
Mblizzard   Well as others have seen, things got ugly! ...   Aug 13 2019, 06:33 AM
914forme   You will always pay when you rush. My suggestion ...   Aug 13 2019, 07:00 AM
Mblizzard   You will always pay when you rush. My suggestion...   Aug 13 2019, 07:16 AM
Mblizzard   OK so I am getting back on track. Big shout out t...   Aug 15 2019, 08:42 AM
mepstein   One of our guys was building an engine for himself...   Aug 15 2019, 10:19 AM
Mblizzard   Well things are back to square 1 essentially Well ...   Aug 22 2019, 06:46 AM
DRPHIL914   Mike it looks like you just may make it on time...   Aug 22 2019, 07:20 AM
Betty   :cheer: :cheer: :cheer: :cheer: :cheer: :chee...   Aug 22 2019, 04:01 PM
Mblizzard   14-hours in the garage and the short block is done...   Aug 24 2019, 05:15 PM
ClayPerrine   14-hours in the garage and the short block is don...   Aug 24 2019, 07:37 PM
Mblizzard   14-hours in the garage and the short block is do...   Aug 25 2019, 03:59 AM
Betty   Never give up, for that is just the place and time...   Aug 25 2019, 06:00 AM
ClayPerrine   http://www.914world.com/bbs2/uploads_offsite/dekke...   Aug 25 2019, 06:10 AM
Mblizzard   Did a lot of rechecking on parts Sunday. Not much ...   Aug 26 2019, 08:11 AM
maf914   Mike, thanks for posting this build thread. This ...   Aug 26 2019, 09:31 AM
Mblizzard   Mike, thanks for posting this build thread. This...   Aug 26 2019, 10:09 AM
ChrisFoley   Mike, thanks for posting this build thread. Thi...   Aug 29 2019, 05:53 AM
Mblizzard   [quote name='Mblizzard' post='2741742' date='Aug ...   Aug 29 2019, 06:47 AM
Mblizzard   Well pulled the case apart again and could not fin...   Aug 28 2019, 08:19 PM
mepstein   Stephen Stompski stops by our shop ever couple mon...   Aug 28 2019, 08:23 PM
Mblizzard   Stephen Stompski stops by our shop ever couple mo...   Aug 28 2019, 08:36 PM
maf914   Mike, I'm sorry my comment regarding what loo...   Aug 29 2019, 09:35 AM
Mblizzard   Mike, I'm sorry my comment regarding what lo...   Aug 29 2019, 09:49 AM
Mblizzard   Brutal day. Got the valve train setup. Took about ...   Sep 1 2019, 07:08 PM
Mayne   Looking great! It’ll get there and it will b...   Sep 1 2019, 08:50 PM
ClayPerrine   Mike, I think you forgot to install the other two...   Sep 1 2019, 08:59 PM
Mblizzard   Another brutal day building but really made some p...   Sep 2 2019, 07:35 PM
Betty   GO MIKE!!!!!!! :cheer...   Sep 2 2019, 08:17 PM
Mblizzard   Did not have time to completely unpack and get pic...   Sep 4 2019, 07:20 AM
Mblizzard   Did not have time to completely unpack and get pi...   Sep 4 2019, 08:14 PM
914forme   :agree: 100% Chris' stuff is always :worship:...   Sep 4 2019, 06:10 PM
Mblizzard   No time for pictures but it is in! Will sk...   Sep 6 2019, 07:13 AM
malcolm2   No time for pictures but it is in! Will s...   Sep 6 2019, 07:16 AM
Mblizzard   No time for pictures but it is in! Will ...   Sep 6 2019, 07:26 AM
malcolm2   I am considering not going but my wife says I c...   Sep 6 2019, 07:56 AM
Mblizzard   I am considering not going but my wife says I ...   Sep 6 2019, 08:03 AM
ClayPerrine   No time for pictures but it is in! Will s...   Sep 6 2019, 07:32 AM
Mblizzard   No time for pictures but it is in! Will sk...   Sep 6 2019, 08:12 AM
ClayPerrine   Now just have to chase down all those issues like...   Sep 6 2019, 09:19 AM
ClayPerrine   Mike.. when you get a minute we would love an upda...   Sep 7 2019, 07:17 PM
Mblizzard   Last push in the mornings and should try starting ...   Sep 7 2019, 08:37 PM
Betty   Last push in the mornings and should try starting...   Sep 7 2019, 10:20 PM
Mblizzard   Well things took longer than they should but got e...   Sep 8 2019, 09:14 PM
DRPHIL914   Well things took longer than they should but got ...   Sep 9 2019, 07:27 AM
ClayPerrine   Sorry dude. BTDT.....That is a letdown after all ...   Sep 9 2019, 05:40 AM
Betty   :cheer: :cheer: :cheer: :cheer: :cheer: :chee...   Sep 9 2019, 04:57 PM
porschetub   Best luck ok .   Sep 10 2019, 01:45 AM
Mblizzard   Well after all the struggle I have achieved failur...   Sep 10 2019, 06:14 AM
DRPHIL914   Well after all the struggle I have achieved failu...   Sep 10 2019, 06:18 AM
- Lo-Fi Version Time is now: 10th November 2024 - 01:23 PM
