Need another trunk torsion bar roller, Can’t remember where I got this metal one... |
oakdalecurtis |
Apr 17 2019, 04:51 PM
Oakdalecurtis Group: Members Posts: 1,327 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
jcd914 |
Apr 17 2019, 05:52 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I think we used to order then from Automotion but that was a long time ago.
I have a metal one that is damaged (it stuck and the spring wore a flat spot) and needed replacing so I just ordered a set of plastic ones from 914rubber. I'll look to see if I still have the other metal one from the other side that was not damaged. If I have it you are welcome to it free of charge. Jim |
oakdalecurtis |
Apr 17 2019, 06:45 PM
I think we used to order then from Automotion but that was a long time ago. I have a metal one that is damaged (it stuck and the spring wore a flat spot) and needed replacing so I just ordered a set of plastic ones from 914rubber. I'll look to see if I still have the other metal one from the other side that was not damaged. If I have it you are welcome to it free of charge. Jim Thanks JC, will wait to see if you find it... |
Lo-Fi Version | Time is now: 24th May 2024 - 07:46 AM |
