Stalling at low idle when warmed up, Stalling |
tsvo |
Apr 17 2019, 06:44 PM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
I have a 1973, 1.7 with FI still on it. The car is stalling at idle after the engine warms up. Any ideas what to adjust or look for? Things that may be contributing, but not sure. I think there is a vaccum leak. It smells like it is running rich. I recently replaced the fuel pump.
Any help is much appreciated. Thanks, Terry |
dr914@autoatlanta.com |
Apr 23 2019, 02:53 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
check the dwell angle first, closed points make many assume that they have a fuel injection problem. After that check to see that the engine is running on all four cylinders then check to see if the pressure sensor is leaking vacuum causing too rich a mixture
I have a 1973, 1.7 with FI still on it. The car is stalling at idle after the engine warms up. Any ideas what to adjust or look for? Things that may be contributing, but not sure. I think there is a vaccum leak. It smells like it is running rich. I recently replaced the fuel pump. Any help is much appreciated. Thanks, Terry |
Lo-Fi Version | Time is now: 17th May 2024 - 05:40 PM |
